Cam Change with Gears???
Old Aug 27, 2002 | 10:13 AM
dpoelstra's Avatar
dpoelstra
I am planning on changing my timing gears on my 86 F350 460 to a straight up set. I have never changed a cam with out tearing down the motor, so I am curious about how tough it is to change the cam while the engine is in the truck.
I suppose the intake will have to come off...and the radiator will have to come out. Am I biting off more than I really want to chew? Are there any bugaboos I am not thinking of?
For towing purposes, will a cam make enough of a difference to make the work worth while? Will I get enough of an improvement with just the gear set? How good is the stock cam...really?
The truck runs great with the 750 Edlbrock and MSD ignition, but I would like a stronger low end. I hate making decisions like this with out some informed feedback, so the more the merrier.
Thanks
Old Aug 27, 2002 | 12:01 PM
beetle's Avatar
beetle
I would recommend just changing the timing gears and chain to a pre-'72 setup. I had this done on my 85 / 460 and it made a big difference in low rpm torque and pulling power. Changing your cam could open up a can of worms in terms of poor performance. Go with the timing gears, you won't be sorry!
Old Aug 27, 2002 | 12:33 PM
dpoelstra's Avatar
dpoelstra
Thanks...that's what I needed to know.
Old Aug 28, 2002 | 08:43 AM
georgedavila's Avatar
georgedavila
It's a lot of work to change the cam, a lot of work, but if you're up for it there are no real problems and the performance gain with a straight-up timing set and a cam with longer duration is well worth the effort.
Old Dec 2, 2002 | 11:38 PM
BigF250's Avatar
BigF250
Old Dec 13, 2002 | 11:30 AM
pagere2's Avatar
pagere2
Post Cam Change with Gears???
Are there any concerns with installing a new cam without changing the bearings? Do the bearings have to be installed at a machine shop?
thanks, ron
Old Dec 13, 2002 | 08:34 PM
georgedavila
I've changed cams three times using the same engine cam bearings with no problems. I've never changed cam bearings other than when a block was in the shop and they took care of it, but the procedure looks easy enough to do when the engine is in the rig. Everything's already out of the way.
Old Jul 16, 2003 | 11:21 PM
78 460 5 speed's Avatar
78 460 5 speed
George: I'm new to the performance end of things. I,m changing the crank gear to straight. Would a cam with more duration than stock also help mileage since it is helpng performance like you said? I cruise at 2000 rpm's doing 65
thanks for any advice: just thinking about putting in a mild cam with split duration to help the exhaust flow. Also grinding dn the smog bumps while getting valve job
Old Jul 17, 2003 | 12:26 PM
wtroger's Avatar
wtroger
The 87 and up gear sets are also straight up and they are double roller chains and gears. I like the 260 series Crane cam for the 460 works well with computer controlled engines. Make sure and put in a new set of lifters if you change cams not a big deal you will already have the intake off. I have changed several cams with the engine in place. remove intake, distributor, radiator may be condenser (measure and see if condenser has to be removed before going to that extreme) pull balancer remove timming cover old gears and chain remove thrust plate pull cam out. Butter new cam with breakin lube and reassembly. The cam below will run with stock valve springs and push rods.
__________________________________________________ ___PowerMax
Grind Number H-260-2
Adv. Dur. 260/272°
Int./Exh. .050" Dur. 204/216°
Valve Lift Int./Exh 487/.518
Separation 112°
Idle Smooth
Old Jul 17, 2003 | 01:24 PM
Superdave's Avatar
Superdave
wtroger
How about power difference and did it hurt mileage?
I have just about talked myself into buying the cam you mention, but of course I've fooled around and missed their $20.00 rebate.
Old Jul 17, 2003 | 02:31 PM
wtroger's Avatar
wtroger
TO SUPERDAVE
Mileage improved about 2 mpg. Power is remarkable Mine is 5 speed and it pulls in third and fourth like there is no tomorrow. What I also noticed is that it runs easy throttle response is immediate no bogging no hesitation and the power comes on smoothe and quick.
Just a little back ground the truck is 1989 F-superduty with the flat bed dump on it weighs 9000lbs I have put as much as 5 tons of material on this truck without issues. I also pull a backhoe the trailer for that weights 6000lbs and the hoe weights 10,000lbs
so at times this motor is pulling nearly 25,000 lbs. Since the rebuild I have no issues pulling these kinds of loads. I also put speed pro h535p pistons in which brings the compression into the 9.0-9.2 range.
Old Jul 19, 2003 | 01:23 AM
Superdave's Avatar
Superdave
Thanks for the response.
I have thought about using this cam in my "signature" truck.
Deen Hylton helped me out here by dynoing a few selections I gave him, and for his help, I owe an overdue thanks.
This Crane, H-260-2 appears to be a better cam than the base, Comp Cam Xtreme 4x4 cam. My engine has stock 8:1 compression, stock everything except an Edelbrock 750 cfm carb. This cam swap was to be a spring project, but now its looking more like a late summer project.
Old Jul 19, 2003 | 02:16 AM
85f-250-460's Avatar
85f-250-460
If you put in the pre-72 timing chains will you still pass emmions if you have the rest of the emmions junk on the truck.
and what does a "Shift kit" do?
thanks
Old Jul 20, 2003 | 11:29 PM
Superdave's Avatar
Superdave
85f-250-460
It significantly firms up the shifts of an automatic transmission.
