2002 ford explore
Old Jan 1, 2008 | 12:57 PM
diver1's Avatar
diver1
2002 ford explore
whenever i take off it starts popping and jerking from the back. but once you get some speed up it quits. have had serveral mechanics look at it and they told me it was the tires so i replaced them and nothing has changed.
Old Jan 1, 2008 | 01:15 PM
aquanaut20's Avatar
aquanaut20
You need new mechanics,
and we need better info......
In the meantime, Have you checked for sticky rear calipers?
Old Jan 1, 2008 | 01:45 PM
diver1's Avatar
diver1
i feels like the fourwheel drive is trying to kick in. you can tell it more when you make a turn.
Old Jan 1, 2008 | 01:49 PM
diver1's Avatar
diver1
you can not feel anything in the steering and it does it while it changing gears
Old Jan 1, 2008 | 01:55 PM
diver1's Avatar
diver1
what would be the best way to clean the calipers
Old Jan 1, 2008 | 02:40 PM
aquanaut20's Avatar
aquanaut20
Clean calipers, remove them, clean/lubricate and reinstall,
Check driveshaft U-joints while you are at it, remove driveshaft, feel for rough, loose or binding joints, replace as required, reinstall
Old Jan 1, 2008 | 05:06 PM
MCDT's Avatar
MCDT
I may be totally off base here so my apologies in advance. If the explorer has a two piece drive shaft it sounds like it may be doing the same thing my 97 ranger extended cab would do. the slip joint between the two shafts would bind. cut the band and slide the boot back and work some wheel bearing grease in then put the boot back and secure with a sinch tie.
Old Jan 2, 2008 | 11:03 AM
antony25's Avatar
antony25
Measure all four tire circumference. Any large difference can cause auto 4x4 engagement and binding.
