I have 1988 F250! Does anyone have any info? Truck ran fine when I pulled in the garage. All I done was hook up the entire plow setup. I tried to put a new fuel pump in and nuthin. aaaaaaaaahhhhhhhhhhhhhh! There is no noise when you turn the key. (Coming from the tank) ya know that humm you usually hear when the pump kicks in, a buddy said it could be the front/rear fuel tank switch but I dont know much about those switches. Any info or suggestions will be helpful. Thanks
will the switch from front to rear get stuck to where neither one will allow fuel? thats what a friend suggested but i dont know anything about those switches
