towing capacities????
Old Dec 31, 2007 | 09:21 PM
avator's Avatar
avator
I know this has been covered before... and I just looked through about 20 pages of old posts, and couldn't find my answer:
what is the towing capacity of an '99, 4.6, long wheel base F-150 XL? it has an automatic transmission/OD & 2.55X16 tires.
I plan to get a small (22-26FT) travel trailer and want to make sure there I don't over tax my truck. most fo the trailers I've looked at so far has been in the 3,800 - 4,200 pound range. I will be carrying about 750 pounds in the bed.
I realize I will need to re-gear the truck, probably to 4.10s. what will that do to my capacity? increase it?
thanks for the help.
Old Dec 31, 2007 | 10:01 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
You will be very disapointed with the performance towing nearly any TT over 15'. I used to tow my 18'tt with a 4.6L. I killed the tranny in 1 year. Also very slow on hills, over heating up hill and couldnt hold 60 on the freeway.
Old Dec 31, 2007 | 10:09 PM
avator's Avatar
avator
thanks.... I guess. it's not what I wanted to hear. but, I do want to know what others have already found out. there are a couple of smaller TTs on the market I've looked at too..... but, am concerned about doing anything more a couple of days at a time. I really wanted something I could hit the road for a couple of weeks at a time. might have to go with my first instinct - a 13 ft "new" vintage Scotty.
Old Dec 31, 2007 | 10:33 PM
MARTYSTOWRIG
what about a small 5th wheel. I have seen them being pulled by Dakotas and such.
Old Dec 31, 2007 | 10:47 PM
avator's Avatar
avator
that's a good idea... but I need the bed for my motorcycle.
Old Dec 31, 2007 | 10:53 PM
grafekie's Avatar
grafekie
Its actually pretty good... over 5k for sure. Let me look it up in my 1999 manual tomorrow 4x4 or 4x2?
Old Dec 31, 2007 | 10:54 PM
avator's Avatar
avator
4x2.
thanks
Old Dec 31, 2007 | 11:02 PM
Mr Jimi's Avatar
Mr Jimi
How about a pop up, lite and nice
Old Dec 31, 2007 | 11:06 PM
MARTYSTOWRIG
Pop ups are nice if you go to one place and hang out for a few days before packing up and going home. My wife and I decided against it after taking a trip for 10 days and staying at one place for more than 2 nights. The packing folding and cranking gets old if you have to do it every day. Also in the winter they can be drafty and in the summer can be HOT, I know you can get AC units for them but..... WHY.
Old Dec 31, 2007 | 11:18 PM
avator's Avatar
avator
pop-ups certainly have their place. I've been there, done that..... and would really like something a little more substantial. plus, around here, pop-ups run almost as much as a hardsided trailer. and like MARTYSTOWRIG said, all that cranking and setting up can get old.
Old Dec 31, 2007 | 11:20 PM
Hooksetter's Avatar
Hooksetter
http://changingears.com/rv-sec-tow-v...-ratings.shtml
Old Jan 1, 2008 | 07:56 AM
grafekie's Avatar
grafekie
Need more info...
1999, F150, Reg cab, 4x2, 4.6L, auto, 3.08 gears: 5,600lbs
1999, F150, Reg cab, 4x2, 4.6L, auto, 3.55 gears: 7,200lbs
1999, F150, Ext cab, 4x2, 4.6L, auto, 3.08 gears: 5,500lbs
1999, F150, Ext cab, 4x2, 4.6L, auto, 3.55 gears: 7,000lbs
Old Jan 1, 2008 | 08:15 AM
avator's Avatar
avator
Need more info...
grafekie,
thanks. that just about says it all. looks like I need to stick to a trailer weight of under 3,000 lbs to maintain my comfort level.
Old Jan 1, 2008 | 09:01 PM
CougarXR02's Avatar
CougarXR02
are we reading the same post? those tow ratings to me indicate, while considering the bike in the bed, you should be more than comfortable with a 4000# dry trailer. especially if you regear to 4.10.
Old Jan 1, 2008 | 09:10 PM
avator's Avatar
avator
if I have 4.10 gears installed, I'll be OK. if not, then I'll stick to a lower weight limit. I plan to do some mountain driving - therefore, I'd feel comfortable towing something in the 3,000 - 3,500 lb range. add my bike (740lbs) and some gear - and I'm over 4,500 lbs. I can't imagine towing any more weight than that up some of the Rockie Mountain passes.
BTW: can someone give me a clue what 4.10 gears might cost me - installed?
