Sponsored by: Real Truck
Silly question ??
Old Dec 31, 2007 | 03:23 PM
cactus224's Avatar
cactus224
Silly question ??
New to v-10s, there seems to be alot of engine braking on this engine. I had a f150 with 5.4 but when you take your foot off the gas on the V-10 it really slows down alot faster than the f150. Is this normal,
Old Dec 31, 2007 | 03:34 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, this is normal. Just like a V-8 slows you down faster than a 4 cyl, a V-10 will slow you down faster than a V-8.
More pistons pulling against the throttle plate, making more vacuum, slows you down faster.
Old Dec 31, 2007 | 03:36 PM
rmosso1's Avatar
rmosso1
Make sure you don't have it in tow haul mode. I had a 2001 4 x 2 V-10 Excursion and don't remember anything like that. You will get better answers, but you probably should disclose your tranny and rear ratio. Oh, and what is the V-10 powering?
Old Dec 31, 2007 | 03:41 PM
cactus224's Avatar
cactus224
Thanks Its a 99 F250 373 gears 4wd
I thought it was normal with v-10 but wanted to check
