1997 460 EFI (spark knock)
the engine is giving me detonation at mid to full throttle when going from normal cruise to pushing ,like to pass ,or from when you first start out and trying to get up to speed in a quick manner.it's only got 54000 on it,i've never touched the ignition timing either..... any suggestions?????
Assuming no change in timing, check your EGR system, valve, etc, if it fails or plugs up, you're going to ping badly. Also make sure your fuel pressure to the injectors is good, running lean will also cause detonation. Insufficient EGR gas flow should set a code in your ECU, you might want to see if there's any codes stored in there.
I have seen this cured many of times by spraying a can of carb cleaner into the vaccum line from the brake booster. This will remove a bunch of carbon from the piston tops and the back of the valves. It really seems to work. We had a special bottle and chemical at the lube rack that I worked at and we charged 50 bucks for the service but the carb cleanre works just as well.
poshardja
1999 to 2016 Super Duty
32
09-30-2018 06:31 PM
