Sponsored by: Real Truck
03 Power steering?
Old Dec 30, 2007 | 05:43 PM
89stinger's Avatar
89stinger
Red face 03 Power steering?
Hey guys. I am new to this forum and so far I think its awesome! But, I have been reading for a couple of hours and haven't seen what I was looking for. Problem is my 03 SD 6.0 seems to have lost its power steering. Seems to steer ok when on the hiway. Get into a parking lot and then try to get out after it fills up? Virtually no power steering at all. Is there a history with steering pump problems? I have a 6" lift running 33" tires but I don't remember a problem with steering until about 6 months ago. It absolutly won't steer sitting still. HELP!
Thanks, Dan
Old Dec 30, 2007 | 08:31 PM
Going_Going_Gone's Avatar
Going_Going_Gone
The same pump that provides power for the steering also provides boost for the brakes. Turning the front wheels while you have your foot on the brake will certainly tax a weak pump. Are the tires under-inflated? Also, with your 6" lift, I assume that you used a drop pitman arm and track bar mount so that your steering geometry remained close to where it was unlifted. You might also look at www.ford-trucks.com.com as well. Lots of Super Duty experts there.
Old Dec 31, 2007 | 02:51 PM
Beerstalker's Avatar
Beerstalker
Try changing out your fluid first. The fluid can go bad over time and not work as well. If that does not fix the problem than you probably are going to be looking at replacing the pump. There are a few threads on here that talk about aftermarket pumps that are supposed to be stronger than the stock Ford one which will help on your lifted truck.
Old Dec 31, 2007 | 04:30 PM
89stinger's Avatar
89stinger
Thumbs up
Thanks Beerstalker.... good advice. I haven't changed ps fluid since it was new and it is looking a little bit brown.
Old Dec 31, 2007 | 07:33 PM
zx250's Avatar
zx250
Of the next Riffraff East
Just remember the powersteering pumps use ATF and not powersteering fluid.
Old Dec 31, 2007 | 07:41 PM
zx250's Avatar
zx250
Here's a link on how to flush it.
https://www.ford-trucks.com/forums/4...firmation.html
I switched over the syn ATF to quiten a whine I was developing. That was a 1 1/2 years ago and no noise at all.
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
Greywolf
Apr 9, 2012 05:39 PM
Tugly
44
Mar 16, 2012 05:54 AM
6CylBill
35
Mar 7, 2010 08:15 PM
Bowtie_Schmowtie
Jun 14, 2009 08:57 PM
