Bio D
Old Dec 31, 2007 | 02:08 PM
aklim's Avatar
aklim
Originally Posted by JustinSWeber
I put Bio D in my tank not Off road Diesel.
I do have a mini tractor I could use it on.
.. but like the idea of Bio Diesel in eveything far more than price.
Thought we'd warn you first before you got raped by the taxman.
Price rools for me.
Old Dec 31, 2007 | 02:27 PM
stormyrider's Avatar
stormyrider
Around here the fuel suppliers are recommending a B5 initial few tank fulls as this will still clean the fuel system out but it will come off in smaller chuncks and make it through to the main filter up front.
Old Dec 31, 2007 | 02:37 PM
aklim's Avatar
aklim
Still, if he is 3 weeks away, why not wait and do it then so he can go full bore to B100 if he wanted to instead of hoping that it won't clog up the in tank filter and you have to drop the tank befoe you are ready?
Old Dec 31, 2007 | 03:35 PM
JustinSWeber's Avatar
JustinSWeber
I found an oil leak near the rear of the engine... right by the tranny, so I need to fix that first :-(
Old Dec 31, 2007 | 04:40 PM
aklim's Avatar
aklim
Might be turbo pedestal or EBPV
Old Dec 31, 2007 | 06:08 PM
JustinSWeber
God I hope so.... I dont think I have it before adding a tuner or new exhaust... could these have contributed? Could it be a rear main seal leak?
So the obvious choices are Turbo pedestal or EBPV or rear main seal? any others?
It seams like its coming from the starter area or from the TQ converter inspection cover. Those are the only 2 areas really.
I added oil... I was down 1/8 of a qt.
Old Dec 31, 2007 | 06:50 PM
aklim's Avatar
aklim
Could it? Yes. Likely? Not even close. Rear main seal leaks are VERY VERY rare.
Could be your HPOP too. We can't say from here but I suggest you break out a few cans of engine degreaser. Clean the engine off in the valley. Run it for a bit and see where it leaks from.
Old Jan 1, 2008 | 01:02 PM
greagin's Avatar
greagin
could just be a loose oil port as thats where mine was coming from!!
Old Jan 1, 2008 | 06:17 PM
lee231's Avatar
lee231
On the AG fuel thing, they don't fine you for the that tank of fuel, it can go to how long you had the vehicle and the miles you put on it from day one. They figure you've doing it since you had it.
Old Jan 1, 2008 | 07:59 PM
aklim's Avatar
aklim
At that rate then, your kids might be having to bail you out.
