A/C for Y-Block
Old Dec 30, 2007 | 11:35 AM
54effy's Avatar
54effy
Question A/C for Y-Block
Can after market a/c be installed on the Y-Blocks. I have a '54 f-100 with I believe a '57 292 that has been stroked. It gets pretty hot in the cab when traveling 500+ miles to Knoxville and other shows. I know I have seen other trucks with a/c. My question is how the performance is effected. Thanks.
Old Dec 30, 2007 | 07:30 PM
matt2491's Avatar
matt2491
Off topic but...
It used to be that when I turned on my headlights the engine would almost die!
Old Dec 31, 2007 | 11:45 AM
332_58 f100's Avatar
332_58 f100
Talking Air conditioning solution
Hot rod air and vintage air both carry brackets to mount ac pumps to the 292. I know that they make kits that require very little modification to the vehicle. As far as the performance i could not tell u because i have not seen one or talked to anyone who has used them on thier vehicles.
Old Dec 31, 2007 | 05:35 PM
54effy's Avatar
54effy
Thanks, I'll check out the brackets. Hopefully I'll find someone that has installed a unit on their Y-block and had good results.
Old Jan 2, 2008 | 10:45 AM
popbreed's Avatar
popbreed
I have a 56 sedan with a 312 with vintage air unit. Works good, no performance issues but I did add a fan shroud and 6 blade fan to keep the engine cool. I was goign to add an idle solinod to pick up the idle when the A/C was on but nover did it since the engine idles at 700/800 rpm (cam) so didn't need to increase it. I used the Vintage air brackets which result in the A/C compressor mounted where the generator was and had to switch to an alternator mounted above the compressor in front of the right head. One belt runs everything. Debating whether to add A/C on my 64 SW PU with a 292. Probably will not since we seldom use the A/C in the 56.
POP
Old Jan 2, 2008 | 08:14 PM
54effy's Avatar
54effy
Thanks POP. I knew somebody had to have A/C.
Old Mar 1, 2008 | 06:55 AM
Walston's Avatar
Walston
I am in process of putting AC on our 292. It is from Classic Auto. Here is the compressor and alternator set up. The radiator is obviously not back in yet.
JeffLee
Jun 5, 2014 06:34 AM
JohnnyLogic
Tennessee Chapter
Nov 19, 2013 07:50 PM
Y-block
Oct 8, 2013 06:36 PM
e william
Aug 29, 2007 06:50 PM
chipmunck
15
Apr 19, 2005 07:20 PM
