460 mods....again
Ive got the 460 in my truck.....everything is stock....also have C6 tranny
What kind of timing can I run?
If I put just an edelbrock performer intake..and some headers on the 460 what size carb should I go with?
I was looking at a road demon 725 w/ electric choke???? Is that too much???
any other hints are helpful...
Go back down. Turn the distributor a little farther. Run up the hill under WOT at low rpm's. No pinging? a little farther.
Keep going to it pings and back it off. Then go one more time up the hill to make sure your not pinging anymore.
Heres my 2 cents on carb sizing. Now since you have a dual plane intake on your rig im assuming. You did say perfromer. Think about it.....
You just divided half the motor into 2 intakes. so say you want a 650, you got a 325cfm carb per side of the motor. Thats a tad small for your app. I would say at least a 670cfm if you want the most out of the current engine setup.
I dont think a 750 would be out of the question, but thats a little big. A 725 I think is a good choice. But a cam swap would wake that big block right up.....
My 351 windsor I built is using a 600cfm right now. It wants WAY more. Since I have a dual plane, my motor per side has 300cfm.
Granted I got a big cam, ported heads, and really good exhaust. Plus a stroker kit. But dont go all crazy on the carb size.
You know the saying, bigger isnt always better.
So I would say a 7's size carb is a good idea, it allows you to upgrade further down the road and your gunna get a good kick in power. So I say i'd say go for it.
which might be better and easy to play with
Edelbrock 750 or Road demon jr 725
I run Edelbrock and I am soundly dissapointed at the help lines and there product doesnt act very consistently. I have a 1407 (750) Edelbrock at home Im going to try just for kicks. The 1406 (600) is NOTHING but problems. Search the forums, there everywhere. And it seems like no amount of tuning can get it right.
I will try the 750 and see how it goes. I know its too much carb, but the heck I got it for $35 and its brand new!
I looked at that demon carb. I think you will be VERY happy with it. Plus it looks alot cooler
, You can go ahead with the Demon but Ill try that carb some time this week if you want an opinion on it. I still say that Demon is the way to go. They can be upgraded, tuned and assembled much easier then the Edelbrocks seem to do.
I was looking at edelbrock since I can find those used....
Not many demons for sale and people have them installed so guess they like it enough not to change
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
