Offroad & 4x4
Leveling Kit.
Old Dec 29, 2007 | 08:05 PM
spacegun's Avatar
spacegun
Leveling Kit.
I like what the leveling kit does for the F150. What do they cost?, what kind of a job is it to install?, who sells them?
Old Dec 29, 2007 | 09:25 PM
bla1879's Avatar
bla1879
Kore might well one, i know they sell for the bigger fords 250+ they are a site sponsor, so check it out
Old Dec 30, 2007 | 12:04 AM
countryboy116's Avatar
countryboy116
Info would be nice, what year is your truck, 2wd or 4wd, i know autospring makes a good kit for the 04+
Old Dec 30, 2007 | 03:05 PM
spacegun's Avatar
spacegun
Looking to order a 2008. F150. 4x4 I don't think it can be very much work to just raise the front end. But it sure does make a difference in the looks.
Old Dec 31, 2007 | 12:43 PM
MBBFord's Avatar
MBBFord
I agree. The best thing anyone can do to the 04-08 trucks is level out the front.
IF you don't plan on towing and you will stay with the stock sized tires, then a 2" or 2.5" Autospring spacer would work great.
I put a 2" on my dad's 04, and taking my time it took me 1 1/2 hours to do one side, and once I knew what I was doing, 1/2 hour for the other.
There are other options, but if you just want the lift spacer, then the autospring is the way to go.
There is a 3" skyjacker lift that includeds new shocks, lifts the front 3", and a 1.5" add a leaf for the rear.
Then bilstein sells coil over shocks(which is what is on the front of these trucks) that can be adjusted to have 2" lift, so no spacer needed.
The reason I'm saying this is b/c the stock shocks will not last more than 30K miles, and they will be shot, requiring you to spend more money and go back and basically redo the job you just did on the spacer, so shocks with a lift would be like killing two birds with one stone.
It would of been easier to help you/quicker if you would of had all the info in the first post.... just fyi
Old Jan 2, 2008 | 08:59 AM
spacegun's Avatar
spacegun
Thanks MBBFORD. That helped a lot.
tbugher62
Oct 18, 2013 11:23 PM
cdmm151
Jan 16, 2012 06:05 PM
Paxdad
Jul 5, 2010 08:25 PM
SDTruckMan
2004 - 2008 F150
Sep 4, 2007 06:07 PM
mrw1125
Jan 11, 2004 01:45 PM
