Sponsored by: Auxito
P0401
Old Feb 14, 2002 | 12:56 PM
p_white's Avatar
p_white
Post P0401
I was hoping someone could have solved my problem. Check out p0401 stumped.
Old Feb 15, 2002 | 05:43 PM
pbrownblksport01's Avatar
pbrownblksport01
P0401
Your code is a problem with your EGR system. The problem is your DPFE sensor. This sensor comes off your EGR tube and is connected by two flexible hoses. One is slightly bigger in diameter than the other.(the bigger one goes to the ref side). It also has an electrical connector on it. Replace it and that should fox youre problem.
Old Feb 18, 2002 | 01:16 PM
p_white's Avatar
p_white
Post P0401
I fixed it. The ports in the plenum were clogged.
Thanks
Old Feb 25, 2002 | 09:06 AM
daw1264's Avatar
daw1264
P0401
Did you remove the Plenum to clear the ports and if so was a gasket needed to reinstall?
Old Feb 26, 2002 | 02:34 PM
p_white's Avatar
p_white
Post P0401
No.
Old Mar 4, 2002 | 12:59 AM
daw1264's Avatar
daw1264
P0401
Ok the problem is now fixed, but its not the plenum ports its simply the butterfly body ports, a 45 minute job and not the plenum, which would take a few hours.
Old Mar 4, 2002 | 07:47 AM
fordatlast's Avatar
fordatlast
P0401
glb4x4van
Sep 1, 2013 02:20 PM
Schlava
6.7L Power Stroke Diesel
Oct 10, 2012 06:32 PM
rado
Jul 2, 2011 01:40 PM
01ExpoXLT
Aug 24, 2005 11:39 AM
cinnpass
Jul 12, 2002 04:04 PM
