I've installed an AutoLoc power door lock system in my '68 F250 and the actuators aren't strong enough to change the lock position. AutoLoc tells me I need to clean and grease my lock mechanism.
Anyone have any experience with power door lock systems? My impression is that the door locks back then were built much stiffer than they are today. I'm not sure that cleaning and greasing is going to get it done.
Plus, it aint easy to clean that latch mechanism. I've had it soaking for 24 hours and it's not coming that clean and I really don't want to dissassemble it.
What is the rating on the solenoids? The older locks shouldn't take that strong of a solenoid just to unlock them..... You can check the amount of pull it takes to unlock your locks with a fish scale, then make sure this is less then the rating of the solenoid. Clean the mechanism in some stanasol and they should work.
Soaked for 36 hours and cleaned what I could get at with a tooth brush, then greased before reinstalling and the actuators still can't budge it. I assume in the latch there is a detent that you drive over and back when locking and unlocking?
You either have some very worn out locks, or some very weak solenoids... Find a fish scale and see how many pounds of pressure it takes to unlock the lock.
That should unlock the doors, Make shure you have not hooked the solenoids to the part of the latch responsable for opening the doos, this will require a lot of force.
I posted some pictures of the installation in my gallery - you can't post pictures to a thread?
Anyway, I used the metal that came with the autoloc kit to mount the actuators in the opening. It works but it's not really stiff. There is some give to the mount when the actuators tries to work. Should I fab a siffer mount?
