idle surging
Old Jan 5, 2008 | 10:41 PM
  #31
howard90f150's Avatar
howard90f150
Originally Posted by old hog hauler
Hey guys fixed all the problems I had before when I posted with the HO motor and truck intake and electronics.My problem now is the truck surges up and down at idle.I have checked and checked thinking it was a vacuum leak but I can not find anything.Any other ideas.I pulled codes doing the koer test and found these codes,12,42,77 and 52. Does this help at all.Thanks
Code 52 power steering switch. Despite what another poster said earlier it IS USED ALSO ON AUTOMATICS! Is in power steeering line, has wires going to it, easy replacement, maybe your problem. It makes ecm raise idle when your are turning wheels at idle to keep motor from dying.
Old Jan 6, 2008 | 06:06 AM
  #32
old hog hauler's Avatar
old hog hauler
Smile
Thanks I see it did have a switch just needed to get to it and fix it. I finally got the surge fixed with the IAC kit F2PZ9F939A.It a must for all our trucks.Thanks for all the help. https://www.ford-trucks.com/forums/6...must-read.html
bwolgie
Mar 11, 2015 03:35 PM
almonyspm1
Sep 21, 2013 08:27 PM
Staytuned25
Mar 25, 2011 09:04 AM
build4
Modular V10 (6.8l)
Jul 1, 2009 12:11 PM
wintremute
3.0L V6
May 16, 2006 08:44 PM
