Gutless when cold??
Old Dec 29, 2007 | 11:18 AM
nightskyisme's Avatar
nightskyisme
Gutless when cold??
Title says it all.....when I drive away cold (just started) there is no power....barely moves itself along, no matter how far I push the peddle.
After like 1/4-1/2 mile, she runs fine and has it's power.....this normal? All filters good, glow plugs are fine and both relays (gpr and manifold heater) are switching on.....anything to check?
Old Dec 29, 2007 | 11:22 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you didn't know, diesel engines do run on heat ignition, there is no spark to fire the mixture. When you don't have heat, it runs poorly. Take it easy on the truck until the water temp gauge begins to move.
Old Dec 29, 2007 | 12:51 PM
jeepster1272's Avatar
jeepster1272
Plug it in thats what I do.
Old Dec 29, 2007 | 01:30 PM
nightskyisme
So what your saying is normal operation? I assume the glow plugs (since they cycle on and off after running) would provide enough heat to combust. Plugging it in isn't possible where I park for long periods.
Old Dec 29, 2007 | 01:33 PM
tholt34's Avatar
tholt34
Sounds like normal operation to me. I just moved into an apt and i can't plug mine in anymore and mine is the same way. After the temp needle starts to move it runs like normal.
Old Dec 29, 2007 | 02:24 PM
1996pwrstrk's Avatar
1996pwrstrk
The glowplugs only work to start the engine once it is started the are not needed.
Old Dec 29, 2007 | 03:24 PM
IDPisan's Avatar
IDPisan
Sounds like your ebpv is working to me. The pcm controls it when the air temp is around 45 degrees and the oil temp is around 165. I'll look for a thread that explains it better.
Here ya go, https://www.ford-trucks.com/forums/6...=ebpv+pedistal
Old Dec 29, 2007 | 04:30 PM
badger2196's Avatar
badger2196
...but they do stay on well after the truck is started when it's cold - my newly installed GPR indicator assures me of that. Details of WMRiceMan's excellent idea can be found here.... https://www.ford-trucks.com/forums/6...=glow+plug+led
As for poor performance when cold, it's a diesel thing!
Old Dec 29, 2007 | 04:52 PM
RogueSpear2023's Avatar
RogueSpear2023
It's normal, diesel engine doesn't like being cold, but then again niether do I so at least we agree with each other. If you don't have a remote start that may be something to look into warm it up 5 min before you go, then it runs fine.
Old Dec 29, 2007 | 05:04 PM
nightskyisme
Thanks guys, all sounds normal then....appreciate your input
