General Diesel Discussion
Cleaning Tips
Old Dec 28, 2007 | 10:44 PM
brian42's Avatar
brian42
Veteran: Navy
Thumbs up Cleaning Tips
I don't know where to post this so I'll just put it here.
I learned a couple of neat tricks this weekend I thought I'd share with my diesel bretheren.
To clean your oily, nasty, greasy, grimy CAC tubes use waterless hand cleaner. Slather it all over the tube and rub it in with your hands. Use some shop towels and wipe off the tubes. Repeat the process until your tubes are as clean as you want them.
To clean stains off of your engine block: dip a nylon brush into white vinegar (or pour some on the block) and scrub. Rinse with fresh water. Done.
They saved me a lot of time and I thought that it might save somebody else some time too. Enjoy!
Old Dec 28, 2007 | 11:25 PM
scatgo's Avatar
scatgo
CCA tubes?
Old Dec 28, 2007 | 11:46 PM
brian42's Avatar
brian42
Veteran: Navy
CAC (Charge Air Cooler) tubes...aka turbo intercooler piping. They are the metal intake tubes that go from the turbo outlet to the intercooler inlet and from the intercooler outlet to the intake plenum of the engine.
Old Jan 13, 2008 | 08:22 PM
oltrucker's Avatar
oltrucker
clean the engine?why? i have enought to do,,i only wash the truck once every 6 monthes. mother natures rain does a pretty good job. hell, the fuel hog only gets used when there is no other way to do a job. the less i use it, the more money is in my pocket.
Old Jan 14, 2008 | 10:06 AM
brian42's Avatar
brian42
Veteran: Navy
Because when you have to remove the CAC tubes to get at the head you might as well clean them off so you don't get slimed twice.
And the vinegar comes in handy when you finally fix that coolant leak and you don't want your electical connections permanently encrusted in dried coolant (it also works to clean the water pump flanges for a better seal).
I clean for preservation, not beautification. I bought a diesel to work hard, not look show ready!
Old Jan 14, 2008 | 10:12 AM
squaredancer's Avatar
squaredancer
Thanks for the cleaning tips. I'll try them in the next week or two. Gotta go camping and square dancing first.
GO NAVY !
Old Jan 17, 2008 | 08:05 AM
PhotoEd's Avatar
PhotoEd
Washing entire engine compartment?
Are there any tips/suggestions to washing the entire compartment?
A. Don't do it.
B. Power Sprayer on low with engine running.
C. Engine off.
D. ????
Old Jan 17, 2008 | 10:53 AM
Ponyboychris's Avatar
Ponyboychris
Clean engine = 10 extra HP
Old Jan 17, 2008 | 11:16 AM
brian42's Avatar
brian42
Veteran: Navy
A. Don't do it.
C. Engine off.
D. ????
A!!!!! I keep my engine compartment clean (by hand) but would never intentionally spray pressurized water in there. I used to do it when I was younger (and had a carburetor) and stupid. Too many horror stories for no gain (who sees your engine with the hood down).
Old Jan 17, 2008 | 01:45 PM
Joshua0606's Avatar
Joshua0606
Simple Green and a towel works great in the engine bay, just make sure its cool.
Old Jan 17, 2008 | 02:04 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I spray simple green all over the engine, then spray with water hose. Might brush the bad parts then spray with hose. Once finished, crank engine and let run to dry every thing out.
Course you need to cover the intake and don't spray on the alt.
Old Jan 17, 2008 | 02:15 PM
Joshua0606's Avatar
Joshua0606
I love simple green it cleans good and has an ok smell.
Old Jan 17, 2008 | 02:22 PM
miller_feed
I do this every few months. A pic in my gallery shows how it looks. I like the fact that it doesn't leave a film on everything.
Old Jan 18, 2008 | 03:53 PM
slowmans's Avatar
slowmans
I usually wash mine 2 or 3 times a year and have never had any problems? its clean!
Old Jan 18, 2008 | 11:53 PM
07psdrookie's Avatar
07psdrookie
Mines too new to be dirty But when it's time....I'll just bribe the mechanics at work with cigarettes to STEAM (not pressure!) clean it.
Wyatt66f100
Feb 15, 2021 10:09 PM
00Dave
16
Feb 24, 2014 12:54 PM
brain75
43
Apr 30, 2012 04:51 PM
pullinair
19
Oct 5, 2008 09:56 PM
rods4life
Dec 10, 2006 11:41 AM
