overboost annihilator
Old Dec 28, 2007 | 07:53 PM
mattpowerstroker's Avatar
mattpowerstroker
ok guys need your help i put the overboost annihilator in cause i was tired of seeing the ses light come on when it hit 25 psi but im sill having the ses light come on and sending the same trouble code of a high boost sesor is there something else wrong or should i adjust the overboost down the directions said they were set between 22 23 psi so i dont now what is going on any suggestions
Old Dec 28, 2007 | 07:54 PM
ron's power stroke's Avatar
ron's power stroke
http://www.itpdiesel.com/other/Overb...structions.pdf
Old Dec 29, 2007 | 12:43 AM
Tenn01PSD350's Avatar
Tenn01PSD350
I wouldn't mess with it unless you have the equipment to verify the setting you are going to. It is set at the shop at 22-23 PSI to optimize fueling beyond that boost. What is the code # you are getting?
Old Jan 14, 2008 | 04:25 PM
viperbluelx's Avatar
viperbluelx
I just installed the overboost annihilator and I too have the same overboost code as I did before...
