Need better MPG
Old Dec 28, 2007 | 06:17 PM
evan2000's Avatar
evan2000
Need better MPG
I am interested in getting better mileage along with a bit more power. I don't want to mess with exhaust and really don't want gauges. The truck has a K&N air filter, otherwise is stock and has been since new. What are my best options out there. This truck will get 16 mpg if driving in the 55 to 65 range on the highway otherwise is drops to 13. Pretty respectable given the size of the vehicle. I am hearing it can do better.
2000 F250 w/ 7.3 diesel
4WD
191,000 miles
Crew Cab/short box
Old Dec 28, 2007 | 06:22 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
It can do a whole lot better. First thing to toss is that K&N. Go to the 6637, get a tuner, I don't have Jody's because of lack of funds but what I have does the job. Get rid of the OEM exhaust and go to a straight no muffler 4". Plenty to choose from. You will get lots of suggetions here, I am just getting the ball rolling for you. I can get 23 mpg highway with very little effort. 19 mpg around town is commonplace for me.
Old Dec 28, 2007 | 06:31 PM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE
few thing you can check for MPG..all though K&N is not the best air filter for a diesel ..make sure it is clean..look at the up pipes going to the back of the turbo for any soot..you will need to get under the truck and look up at them as well..also look where they bolt to the exhaust manifolds..any sine of soot is an exhaust leak..any loss of exhaust before the turbo will kill performance..also make sure all 4 boots from turbo to inter cooler are tight, clean and in good shape..also the 2 boots under the spider pipe going down into the valley....you can also use this link to make sure the EBPS tube is clean and free of soot..
http://guzzle.rbmicro.com/ebps.html
taking the cat and muffler off will free up some back pressure and give you more power and better MPG..also getting rid of that K&N and doing the 6637 filter for around $50 will help it breather better..giving you more power and MPG as well.. after that you can add a chip..but gauges really should be instaled before the chip..
Old Dec 28, 2007 | 09:00 PM
medhvac's Avatar
medhvac
4WD
191,000 miles
Crew Cab/short box
heck i get that with my truck!
Old Dec 29, 2007 | 04:49 AM
skibender's Avatar
skibender
Make sure your tire air pressure is correct. Check your sticker inside the drivers door jamb - that's the pressure you should be running. I know I had to add air to my tires once the Wisconsin cold winter came.
It looks like your in South Dakota so I'm assuming you have the winter blend diesel. You'll lose a couple MPG's with that stuff. My fuel mileage drops approx. 2 - 4 mpg in winter.
Old Dec 29, 2007 | 06:26 AM
JLDickmon's Avatar
JLDickmon
that's the biggie, right there.
winter blend fuel BLOWS
coupled with lower temperatures, stiffer driveline fluids; you guys in warmer climates ain't got no clue what whe go through up here...
if you want to read my ongoing diary of my fuel economy fight... https://www.ford-trucks.com/forums/6...ss-a-rant.html
I can trace my fuel economy drop to two days... nearly 16 down to around 13.. the day the bio-refiner went **** up..
13 to 10... the day the station down the road started winter blend fuel...
so, change your oil, change your driveline fluids (both diffs, t/c case, transmission), change your power steering fluid, make sure your tires are properly inflated, don't run it in hubs locked unless you have to, plug it in for a couple hours before you get going in the morning, put in clean filters (fuel, oil, air), change where you're buying your fuel, add a cetane booster and a quart of TCW3 on each tank (30 gallons)... ditch the ultra-agressive Gumbo Thornbird Terra Grapplers for something with less drag in the tread...
boiled shrimp, fried shrimp, shrimp cocktail, shrimp gumbo.. that's about it..
Old Dec 29, 2007 | 08:48 AM
RogueSpear2023's Avatar
RogueSpear2023
I get better than that in the summer, but now that it's winter that's about the best you gonna get. The problem is that winter diesel doesn't get as good of mileage as straight number 2 that we get in the summer up here. Exhaust wise something you could do now cheap is cut out the muffler, it doesn't increase the noise in side that much, nor out side for that matter, unless you really stand on it. Make sure you add either diesel kleen white bottle, or schaffers winter blend fuel additive every tank that should increase your mileage a bit, plus your truck will run a lot better. Keep you foot of the gas pedal and keep the rpms below 2000rpm that's were you are going to get the best mileage. As far as the K&N goes get rid of it, they are well known for letting dust by and destroying your turbo. Get a 6637 or go back to stock anything is better than that K&N in turbo charged vehicle.
Old Dec 29, 2007 | 10:26 AM
evan2000's Avatar
evan2000
What is a 6637 and who sells it. Is it a complete air filter box change?
Old Dec 29, 2007 | 10:45 AM
Markadeck's Avatar
Markadeck
I'd answer that except for the fact that there are thousands of post's here at FTE involving the what and how to's involving the 6637.
Old Dec 29, 2007 | 11:22 AM
ron's power stroke
i will answer that for you...i can spare just a minute getting the thread..
just read this thread.. get the filter at napa part# 6637 and a 3"long piece of 4" exhaust pipe..do what the thread said and it shouldnt cost much more then $55..good luck..
Old Dec 29, 2007 | 11:50 AM
RogueSpear2023
Here's some more help with the 6637: Linky
This will also show you how to add the filter minder, but the last pick pretty much shows you what it looks like and there are hundreds of posts on the 6637 if you search for it, also there are a couple of guys that have picks of it in there gallery. You may also think it would get wet, with snow or rain but it doesn't works great, plenty of airflow great filtration. You can also get one at fleetfilter.com they are a little cheaper than napa. These sites will also answer a lot of you questions.
Linky2
Linky3
Sort of
Old Dec 30, 2007 | 09:13 AM
dieseloholic's Avatar
dieseloholic
If you decide to do the Kwik 6637 (I think he deserves props) you won't regreat it. You'll feel the added power and your truck and turbo will thank you. Just two notes so you don't freak out and post about this later; 1) yes that is the right filter, it's huge!, but it does fit and 2) there is a definate change in the noise you'll hear when accelerating... my wife says it sounds like Darth Vader under the hood. It's normal, just a lot more unrestricted air being pulled in. Read the posts, take your time. Here are some great links to add to your favorites:
http://7point3.com/Mods.aspx
Old Jan 5, 2008 | 10:13 PM
evan2000's Avatar
evan2000
I completed the 6637 modification today with no problems. I mounted the filterminder in the end of the filter. All fits well. It is obvious that I need to look at exhaust and it won't be a problem and that when it comes to chip time that the DP-Tuner comes highly recommended. It looks like I will need a set of gauges. As long as I am doing this, I would also like to include tranny temp since my stock setup does not have that. Are there any favorites for gauge setups that are economical?
Old Jan 5, 2008 | 11:06 PM
bandlgeorge's Avatar
bandlgeorge
DP is awesome!! Switched to stock tune on the fly the other day. Forgot what a slug my truck was on stock compared to DP 80E. Got my gauges from Brian at Diesel power products.com Wasn't the cheapest, but I like the clarity of the Dipricol's and the install was easy. Did 2 F350's in one day. I like the full sweep tranny, although I have yet to see mine go above 140. (Don't tow alot yet)
Let the PMS continue!!!!!
Old Jan 6, 2008 | 04:23 AM
ron's power stroke
i got autometers from pure diesel listed at the top of this page..many of our sponsors sell them as a pkg. the A piller pod with three gauges for around $300..you need the pyro,boost and trans temp...
