Strange idle speed problem solved
Old Jan 17, 2008 | 02:15 PM
97ranger xlt's Avatar
97ranger xlt
ok there is something still not right. next i would do
following -
-disconnect negative terminal on battery wait 10 mins. to reset computer then reconnect, start engine and turn on everything electrical and turn wheel stop to stop a few times then drive it stop + go etc
-when the warm engine is idling at 1000rpms unplug the electrical connector to the IAC solenoid. see if idle changes ie. drops
-possibly the new pcv (aftermarket?) is bad .. maybe try get a motorcraft one?
-bang head on wall
Old Jan 17, 2008 | 10:18 PM
texan2004's Avatar
texan2004
Please keep posting about this. Pulling the IAC connection while it's idling high is something I had not thought to do on mine. It's been replaced but I am now curious to know if this does anything to the high idle I get. Problem with mine is not that it idles high continually. Mine idles high when I come to a stop and continues to doso for 5 seconds or so before dropping to nrmal idle.
Old Jan 18, 2008 | 06:09 AM
97ranger xlt
unplug just to see if it goes into open loop. i actually took mine off and tested it on the battery to see if i could hear the solenoid working at all...
sometimes cleaning the IAC with carb cleaner will get it working agian if it's just gummed up with carbon etc
Old Jan 18, 2008 | 10:04 AM
texan2004's Avatar
texan2004
I just replaced the IAC and it still does it. I'm wondering if it might me a bad PCM.
Old Jan 18, 2008 | 10:14 AM
97ranger xlt
well u know those computers are really simple.. more likely u hv a vac leak like through pcv valve. which won't throw a code either.
also it may be that the computer needs to be re-flashed by Ford.
Old Jan 18, 2008 | 10:20 AM
texan2004's Avatar
texan2004
I'll check the PCV valve.
Old Jan 21, 2008 | 05:42 PM
michigan66's Avatar
michigan66
Reset the computer. High idle problem on initial cold start persists. Idle is normal on subsequent restarts.
Old Jan 21, 2008 | 07:05 PM
97ranger xlt
is the MAF and the IAT sensor inside the intake tube clean?
Old Jan 22, 2008 | 08:48 AM
michigan66's Avatar
michigan66
Yes, they have both been cleaned and then IAT was replaced.
Old Jan 22, 2008 | 09:09 AM
97ranger xlt
try unplugging the IAC solenoid (engine warmed up but not restarted)and see if the idle drops or not.
Old Jan 23, 2008 | 08:57 AM
pawpaw's Avatar
pawpaw
My intermittent high idle, when coming to a stop, was traced to carbon deposits on the IAC plunger shaft, where it goes through the shiney baffel into the solenoid/electrical end. Cleaned that shaft real good & it has been ok for 4 weeks now.
So if the IAC cleaning or tests don't prove out, maybe suspect a sticking throttle plate.
Ford coats theirs with a non stick surface & doesn't recommend cleaning, so be careful of what you use & how you do it, so as not to remove or damage the coating, if you find it's dirty. I'd also remove it for cleaning, so you can see what your doing & no need to have the deposits or cleaner going into the intake manafold, or being ingested by the engine!!!!
If there are carbon or gum deposits on, or around the throttle plate, causing it to stick, it'll upset the idle rpm.
Edit: also check the throtte cable & throttle plate connections for damage, deposits, corrosion & inside the cab, for obstrctions around the gas pedal, like balled up floor mats, ect.
Just a couple more thoughts for ponderng.
