frame differences pos axle swap
Old Dec 28, 2007 | 11:26 AM
arockyway2go's Avatar
arockyway2go
Question frame differences pos axle swap
Hey all I got a question.I have a 86 f-250 lariat 2wd and a 88 f-350 4wd.The 86 is absolutely perfect except for door panels(sun damage).The 88 is just a power train.Here is the question-Which would be easier and or faster,converting the 2wd to 4wd via 4x4 conversion spring mounts t-case etc etc,or taking the body off the 86 and putting it on the 88 chassis.Are the frames the same 2wd verses 4wd if not what's the difference?I noticed the front cross-member is the same this is why i am asking.If anyone has done this i would appreciate any tips and tricks or pics.
Old Dec 28, 2007 | 04:17 PM
Franklin2's Avatar
Franklin2
The 86 has coils in the front correct? Swapping bodies is your only bolt in option. The frame is different.
Click on this link if you want to see my reasoning on the subject.
https://www.ford-trucks.com/forums/6...ml#post5499825
Old Dec 28, 2007 | 08:26 PM
fellro86's Avatar
fellro86
Way faster and easier to swap bodies, I don't need the link to know it, but I am sure it is good info. Even if the frame was the same, still going to be faster.
