Muffler Delete Questions
Old Dec 28, 2007 | 09:57 AM
rocknut's Avatar
rocknut
A couple people have said that just by removing the muffler on a stock exhaust will lower your EGTs by as much as 150 degrees. I've seached and found out the proper way to cut the muffler out. Rotate the one pipe after the Cat up to align with rear tail pipe. I would like a little more sound. So how much louder is this gonna be? I live in the city with houses pretty close and don't want to tick off the neighbors when it's warming up in the morning. My next door nieghbor has a 99 7.3L he wouldn't mind but his wife might. Also will this add the dreaded drone in the cab.
Old Dec 28, 2007 | 01:15 PM
HeavyAssault's Avatar
HeavyAssault
Unless you drag race out of the neighborhood it isn't going to bother too many people. There will always be one who doesn't like it.....
Old Dec 28, 2007 | 02:41 PM
scottman70's Avatar
scottman70
I cut out the muffler in my 04 Excursion and left the cat in place. It is not too loud, when you nail it you hear a pretty good growl but nothing that would be piercing to your ears or anything. Cut it out and worst case if you don't like it, have an aftermarket straight through performance muffler installed! I love mine, sounds really good now and the turbo spools faster, which is noticeable! I think I am getting about 1mpg better too!
Old Dec 28, 2007 | 02:49 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I cut mine out...at idle and under 2500 RPM's, no problem. If you WANT to hear it, stomp your right foot!! Ahhhhhh...sounds great!
Old Dec 28, 2007 | 11:11 PM
rocknut's Avatar
rocknut
That's what I wanted to hear. I guess I'll go get some pipe and cut my muffler out.
Old Jan 8, 2008 | 05:43 PM
Triple_E_Farms's Avatar
Triple_E_Farms
I think you will be happy with it gone. I love the way mine sounds. You can hear it a little at idle but not much at all. But like the others said when you hit the gas pedal it sounds great between 2500-3000 rpm. Even better if it is lugged up a little pulling a load. It also makes your tow/hual sound great when its slowing you down.
I have an 04 Crew Cab , Cab and chassis with a flat bed on it and every one that rides in it old and young love the way she sounds when she is going through the gears or when I hit passing gear on the freeway.
Old Jan 8, 2008 | 05:50 PM
tippi98custom's Avatar
tippi98custom
i did it to mine as well and i love the sound, but i went 1 step farther and did a cat delete pipe as well, ha im young, it cant get loud enough for me.
Old Jan 8, 2008 | 06:19 PM
07psdrookie's Avatar
07psdrookie
Amen brother!
Old Jan 8, 2008 | 07:05 PM
Cole26's Avatar
Cole26
I cut mine out but i thought it sound like glasspacks...So i ended up going with a MBRP cat back .. I have the cat delete pipe but have yet to try it out..I am much happier with the catback..Plus the price was pretty good
Old Jan 11, 2008 | 02:32 PM
Triple_E_Farms
The louder the better in some cases. I am only 28 but I don't think age has anything to do with it. I really just want my truck to run better and cool off sooner.
I have a couple of friends that have 96 and a 99 powerstroke and after listening to mine they both had their mufflers cutt out. The 99 didn't have a cat but the guy with the 96 got ridd of his kitty too. They are both in their 60's and they thank me every time they see me for letting them listen to mine.
Old Jan 11, 2008 | 02:42 PM
zss42002's Avatar
zss42002
not to take this off the subject but what is the difference in the muffler delete on the mbrp aftermarket exhasut. i am going to get a mbrp eventually and get the cat delete pipe. now what is the difference if i get a muffler delete pipe for the mbrp?? sound, gas, egt's???? is the muffler delete worth it on a mbrp exhasut??
Old Jan 11, 2008 | 06:52 PM
07psdrookie
I'm not sure egt's would lower too much because there really isn't much to an MBRP muffler. It's straight though and shouldn't cause THAT much backpressure. I deleted my cat and have an MBRP muffler and it sounds just a little quieter at 2k rpm than a co-worker that is straight piped. My 0.2
Old Jan 11, 2008 | 07:25 PM
lariat97's Avatar
lariat97
I need to take my muffler off.I've heard a few 6.0s without a muffler & they sound great. I didn't know it would lower the egts or I'd already have it off. I'm kinda low on funds or I'd buy a MBRP turbo back without a cat or muffler. I have a friend with this on his 6.0. It sounds like a jet taking off when he gets into it. I'm in my mid 50s & I've always put loud exhaust on my trucks. It just doesn't sound like a truck without a little growl. I may take it to my friends muffler shop tomorrow & get it taken off. He will do it for $50.
Old Jan 11, 2008 | 09:10 PM
07psdrookie
No sir. You need to take off your downpipe, put a bigger one on. Then, delete the cat, then, delete the muffler.
Old Jan 11, 2008 | 09:23 PM
lariat97's Avatar
lariat97
Your right but it might void my warranty. I plan to ask my dealer & if he will let me without voiding the warranty I'll put a MBRP turbo back on it.
