need help truck died
Old Dec 28, 2007 | 09:24 AM
Bustaduck's Avatar
Bustaduck
going to work this morn. truck started running realy rough like it lost a cylinder.lost power then died. wouldn't start and run after that. got the code reader out got these codes. p0266,p0401,p0404,p0405,p0603,p2285
Old Dec 28, 2007 | 10:15 AM
i eat hybrids's Avatar
i eat hybrids
what engine?
Old Dec 28, 2007 | 10:40 AM
Bustaduck's Avatar
Bustaduck
6.0 with a cold. been running bad for some time. it's dead know
Old Dec 29, 2007 | 05:27 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The 0400 codes point to the EGR, probably needs to be replaced, common thing.
P0266 points to cylinder #2 contribution
po0603 points to the PCM KAM (keep alive memory) happens when truck has a chip.
Not too sure about the p2285 code though.
I'll move this thread to the 6.0 forum to get you more help, faster.
If you can't get help there, your 5yr/100k warranty should cover the repairs minus a $100 deductable. If not, check with a local diesel performance shop, I work with D.I. Performance and they haven't led me wrong yet.
Old Dec 29, 2007 | 07:01 PM
brickie's Avatar
brickie
2285 is injector control pressure sensor circut low.Hope for you its an 04 or up build.
Old Dec 30, 2007 | 07:16 AM
Bustaduck's Avatar
Bustaduck
thanks for reply what is 2285 code does it need to be 04? o3 6.0 with 123000 miles on her. I hauled it to dealer on a role back. like going to a funeral .I wish it had life insurance because I know this is going to get in my pocket .THANKS AGAINE
Old Dec 30, 2007 | 08:51 AM
brickie's Avatar
brickie
It needs an icp sensor.On the 03 early o4 the sensor is under the turbo a real pita to get at.They moved it to the valve cover in 04.You should have them change the wiring pigtail when you replace the sensor.This is a comon failure on these trucks with this sort of milage.I wouldnt worry much if you trust your dealer.
Old Dec 30, 2007 | 09:24 AM
Bustaduck's Avatar
Bustaduck
thanks againe you guys are great. just got a email back on a 02 7.3 with 70,000 miles on it thank i am going to trade what you think?
Old Jan 7, 2008 | 08:59 AM
Bustaduck's Avatar
Bustaduck
went to dealership this morn. my truck has been there for a week. they had the valve covers of it they said it has a high pres. leak? haven't found it as of yet my advise is get the ext. warnty
MiamiPSD
Feb 6, 2013 05:08 PM
Flytyme69
Jun 4, 2010 12:21 AM
superpony18
Sep 7, 2009 09:52 AM
tmartinford
Apr 3, 2007 12:48 PM
brelinsk
Sep 11, 2006 06:26 AM
