Bad GP Situation?
Old Dec 27, 2007 | 08:13 PM
roycec's Avatar
roycec
Bad GP Situation?
Hello again.
I just lost all 8 of my GPs. I guess the controller must have turned them on when I wasn't paying attention. Going the the manually switched route with Berus...
The old plugs were Autolites, and although none of them lost the tips, three of them blew the side out, and were a bit of a pain to extract. Bits of whatever the outer surface is made of are missing. Is this a teardown situation? I sure don't feel like pulling the heads off right now, although I'm beginning to think that I may be losing a little compression on one of the cylinders...
Old Dec 27, 2007 | 08:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How big were the missing tip parts?
Outer skin is inconnel, same thing turbo exhaust fans are made out of.
Well it is inconnel on the Beru plug, no idea what Autolite uses.
What year engine?
Old Dec 28, 2007 | 02:27 AM
PLC7.3's Avatar
PLC7.3
Could we get you to put up a truck signature year, model, trans etc.... it makes the diagnosis of many things so much easier... thanks
Old Dec 28, 2007 | 09:54 AM
roycec's Avatar
roycec
Thanks for the replies. The missing material is on the side of the plugs, and the largest missing portion is about .25" x .25" I'm trying to figure out how to attach a jpeg, but haven't got it yet...
I'm not really sure when during my workday the failure occurred, and am afraid that the engine was probably run for some time with these pieces potentially inside. What is inconnel? I realize that these may be comprised of something entirely different, but will inconnel break apart easily? Will it pass without damage?
Yep, I've been thinking that I need to put up new info, as I've gotten a couple of new trucks. This one is an '84 F350, 6.9, T19, Sterling rear, (4.10?)
Thanks.
Old Dec 28, 2007 | 10:23 AM
roycec's Avatar
roycec
Oops. Scratch the Sterling axle. Mine looks like a Dana cover with a fill plug right in the stamping. Always assumed it was Sterling...
Old Dec 28, 2007 | 10:35 AM
roycec's Avatar
roycec
Okay. Pics of the two worst GPs are now in my gallery. Couldn't seem to insert them directly into the message.
Old Dec 28, 2007 | 10:58 AM
Breech's Avatar
Breech
Here ya go roycec.......
Old Dec 28, 2007 | 06:27 PM
Dave Sponaugle
More than you want to know about inconel, I had to many nn's in it.
http://www.suppliersonline.com/prope...el722.asp#Spec
Valves, valve seats, turbo internals and glow plug sheaths are where you would find inconel in your engine.
Those are so small and thin, they probably went out with the exhaust, but could have been caught by the exhaust valve.
Old Dec 29, 2007 | 07:24 AM
roycec's Avatar
roycec
Thanks, Breech. Howdya do it?
Appreciate it, Dave. That's what I was hoping for. I guess I'll just run it and hope for the best for now. I've got one of those early blocks that someone cracked with the heater. If I can manage to fix the water jacket, then I might pull the heads at that point.
Thanks!
Old Dec 29, 2007 | 10:08 AM
PLC7.3's Avatar
PLC7.3
If you think that a repair is possible to the cracked block at the block heater.. there are a million guys waiting for the answer........ everything possible had been tried and I mean everything. Sorry........
Old Dec 29, 2007 | 11:15 AM
Dave Sponaugle
When you go into your gallery and open one of the pictures there is a "(Forum Codes)" link in the center of the picture at the bottom edge of the picture.
Click that link.
I copy and paste the link below "display full size" into my reply at the location I want the picture to appear.
Here is and example, but I removed the [img] and [/img] tags so you could see the link.
If you click the link, you will be taken to the picture that would have been displayed if I left the tags in place.
https://www.ford-trucks.com/user_gal...oid=74195&.jpg
Old Dec 29, 2007 | 11:18 AM
greythorn3's Avatar
greythorn3
could i get some pictures of these cracked block holes? from the heater
Ray
Old Dec 29, 2007 | 11:24 AM
Dave Sponaugle
That problem was only 83, 84 and very early 85 engines.
Just looks like a crack starting at the block heater hole radiating out away from the hole.
Usually in the general direction the heater element was pointed.
I have seen it, but never took a picture of one.
I should take more pictures than I do.
Old Dec 29, 2007 | 11:33 AM
greythorn3's Avatar
greythorn3
i gpt a 84 with 250000 miles on it and it dont got no cracks around the heater hole, wonder why mine isnt cracked if it did it all the way to 85
Ray
gmhorse
6.7L Power Stroke Diesel
163
Jul 6, 2020 09:16 AM
stevenlee34983
Jan 16, 2013 01:17 PM
big poppa
70
Jan 14, 2013 10:14 PM
ocboat
Mar 18, 2011 07:54 AM
RangerWask
General Automotive Discussion
21
Jan 23, 2006 06:18 PM
