Top end noise when cold
Old Dec 27, 2007 | 04:19 PM
tired86f250's Avatar
tired86f250
My 86 f250 / I-300 makes A LOT of top end noise when started cold (only for a few seconds..) then it quiets right down and is it's normal self. It has about 160k miles on it (hard working miles) but it still runs good on the road. Any ideas on what might be the cause??
Old Dec 27, 2007 | 04:50 PM
Rogue_Wulff's Avatar
Rogue_Wulff
This could be caused by the oil draining back out of the filter. What brand of oil filter do you generally use?
Too heavy oil can also cause this, as thicker oil takes a little longer to reach the fartherest points in the system, which would be the lifters/valvetrain. What type/weight oil do you normally use?
Old Dec 27, 2007 | 04:53 PM
tired86f250
The filter is a Fram and the oil is Valvoline 10w30
Old Dec 27, 2007 | 05:13 PM
Silver Streak's Avatar
Silver Streak
And there's your problem.
Old Dec 27, 2007 | 05:15 PM
Rogue_Wulff
Try a real oil filter, like Wix. Fram filters are junk, IMO. They have glued cardboard ends, a stamped tin "spring", and no anti-drainback valve.
Old Dec 27, 2007 | 07:29 PM
Harte3's Avatar
Harte3
NAPA Gold is fine...made by Wix. Motorcraft fine too. Some lifter clatter is almost normal on these engines on cold starts.
Old Dec 28, 2007 | 02:24 PM
tired86f250
SOME CLATTER...yeah I can see that...but this is straight up scary. Sounds like there is not a drop of oil in it. I will try a different filter next time I change the oil.
Old Jan 12, 2008 | 02:18 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
My 1979 F150 have fram oil filter and oil pressure was 20 psi and it was warm outside.
Well I decide change to motorcraft oil filter with castroal 10W 30 oil now oil psi was 35.
Well fram oil filter I remove it have broke plastic bypass.
There are many people say fram is best. We try told them it worse one but they keep say my truck have 200,000 miles still run good. But when it reach 250,000 engine broke cam and lifter. It have no oil on it.
Old Jan 12, 2008 | 02:41 PM
Harte3's Avatar
Harte3
Fram just doesn't seem to be the product it once was. And their air filters rate low on the tests I've seen.
Old Jan 12, 2008 | 03:50 PM
AbandonedBronco's Avatar
AbandonedBronco
I have this same symptom on my engine. When I start it up, there is a LOT of clatter, to the point where I can actually feel it coming through the truck/seat/me, and then once the oil pressure builds it's whisper quiet.
With mine, this started up after I changed out the lifters because all 12 of them were completely sunk and collapsed. Once the new ones were in, the engine was so much quieter, but I had this when starting up.
Case in point, this is a direct pointer at what is making the noise, which is the lifters. (No clatter on start up with dead lifters / clatter with new, working lifters.) A better oil filter and maybe an oil stabilizer will keep the oil in your lifters for the next time you start it. Then they won't be dry and clacking until they fill up with oil on startup. I know what you mean though, it's quite a bit of noise.
Old Jan 13, 2008 | 10:58 AM
IcemanV8's Avatar
IcemanV8
Had this problem. Tried many different filters.
A Motorcraft filter is the ONLY filter that completely eliminated my start up noise. Give it a shot.
Old Jan 13, 2008 | 12:03 PM
ken's 80's Avatar
ken's 80
Hey tired,
If it's making THAT much noise and you believe it might be a filter, why would you wait until the next oil change????
Invest $5.00 and at LEAST put a different filter on that engine!! You'll "invest" a heck of a lot more if it decides to give up on you.
