Engine oil questions
Old Dec 27, 2007 | 02:15 PM
DocF350's Avatar
DocF350
Hello I'm a newbie here. Been using my 03 F350 6ltr diesel as a snow plow truck. Have always used a 15w/40 oil. Would like to change to a snythethic and or blended oil. The truck has 120,000kms, uses no oil. Temps here -20 to +5 average winter (Calgary area). Its been suggested to use a 0/w30 syn winter and 10/w30 syn summer. The engine works hard for short bursts when plowing snow, in low gear. Lots of gear shifting. Any oil suggestions and interval change times. Also suggested to me was 8-10,000 kms between changes, but change just the filter at half km time......Doc
Old Dec 27, 2007 | 02:27 PM
High_HP's Avatar
High_HP
For those temps I'd use any of the 5w-40 CI4+ rated synthetics that are currently out. Looking at past UOAs Shaeffer's 9000 5-40 synthetic seems to be very good, can be had at just over $4 a quart if bought in bulk. I wouldn't use the 15-40 at those winter temps imho. Best of luck.
Old Dec 27, 2007 | 02:42 PM
DocF350's Avatar
DocF350
Never heard of Shaeffers before, must be American brand.......thanks anyway....Doc
Old Dec 27, 2007 | 03:30 PM
blackhat620's Avatar
blackhat620
DocF350,
Since you are up north look into the Duron or Valvoline 5W-40.
Old Dec 27, 2007 | 03:46 PM
halfbolt's Avatar
halfbolt
I run ESSO XDR 0-40 From, wallymart with great success, I live in Edmonton, so sometimes I have no access to a plug in. Plus it is a full syn. It will cost you around $22 a jug . Ihope this helps Halfbolt
