Accel COPs for 5.4L
Old Dec 27, 2007 | 10:39 AM
anfo's Avatar
anfo
Accel COPs for 5.4L
Has anyone ever use the Accel "supercoil" COPs for the 5.4? Do they buy you anything or just a gimmick? I found 2 kinds at summitracing, one for 2v and one for 3v engines.
Old Dec 27, 2007 | 10:18 PM
royb's Avatar
royb
the spark voltage is controled by the cpu so COP's are a waste of money and usually throw codes. spend $ in other places.
Old Dec 28, 2007 | 10:46 PM
LxMan1's Avatar
LxMan1
They are good inexpensive replacement for bad originals. About 1/2 the price.
The CPU doesn't limit the voltage of the spark, only the duration of the spark. The voltage is determined by how many secondary windings are in the coil. Most performance coils have more secondary windings thus have higher voltage output to the plug.
Old Dec 29, 2007 | 01:32 PM
royb's Avatar
royb
Let me say it another way-
according to the Strategy (2005 & up 4.6 & 5.4 odb III) the cpu does limit the voltage of spark when certain conditions are met.
Old Dec 29, 2007 | 02:35 PM
anfo's Avatar
anfo
So they sound like a good replaceent for my 98 then, I'm sorta doing a full overhaul of all the likly suspects at 140kmi.
Old Dec 30, 2007 | 10:54 AM
royb's Avatar
royb
I'd check them first with a digital multimeter and see if any one of them is bad or doesn't meet specfications if they don't then replace.
Old Dec 30, 2007 | 04:03 PM
mhg's Avatar
mhg
one thing to remember is the coil will only output
the amount of energy that is needed to jump the plug gap
wider gap= more energy
more compression= more energy
if your coil has the capacity to output 100,000 volts and it only uses 40,000
you paid way too much for no good reason
upgrade the stuff that helps your engine
unless you are running a high output engine
coils are not the place to spend money
on the other hand in this case when they are cheaper
replace when needed with the fancy ones
M
Old Jan 4, 2008 | 05:29 AM
kaboom10's Avatar
kaboom10
My personal preference in manufacturers is MSD. They make COP units. The Accel units are about $29/ea and the MSD is about $49/ea. Accel coils output is more than stock and MSD is 40-45kv. If you aren't using the full potential of these units you wasted your money as a whole set of COP I have read are $85/set. These units are great if you are making gobs of power. If you must have a useable upgrade MSD makes a DIS4 unit. 2 units are required ($365-$505/ea) along with 4 wiring harness' (another $248) and maybe a unit to get a tach signal to the CPU. MSD told me this will work with stock COP's. It will give you multispark under 3000 rpm and will fire anything you use.
Old Jan 4, 2008 | 02:57 PM
Fastbird's Avatar
Fastbird
I just replaced mine 600 mils ago and 2 of them went already bad.They are made in china.
Old Jan 4, 2008 | 03:35 PM
kaboom10's Avatar
kaboom10
Just buy OEM at least. Chinese anything is garbage.
Old Jan 5, 2008 | 04:54 AM
vze2sgxa's Avatar
vze2sgxa
Can you really tell a difference at the throttle whether or not it is a performance or just a regular, OEM COP?
Old Jan 5, 2008 | 11:17 AM
kaboom10's Avatar
kaboom10
No unless you need more voltage than an OEM unit can deliver. Then an aftermarket replacement will deliver that extra needed voltage. An engine only needs so much voltage till the requirement surpasses what can be delivered. Then you need to amplify that voltage going to the coil(s). There are many different units available for your specific needs.
simptek
1997 - 2003 F150
23
May 2, 2017 03:25 PM
Methodical_1
23
Apr 21, 2012 11:32 PM
jdhudall
1997 - 2003 F150
18
Jan 26, 2009 08:39 PM
calazo
Jan 7, 2009 10:40 PM
BajaRacer909
1997 - 2003 F150
Jul 24, 2005 11:58 AM
