Weird noise from Navigator
Old Dec 27, 2007 | 12:35 AM
rhino_160's Avatar
rhino_160
This is difficult to describe by typing but i will give it a shot. 2000 Lincoln Navigator 4x4
When stopped and turning left or right, once in motion and turning, i hear a vibration/rubbing/grinding noise coming from what i believe is the rear end. if you are turning left, you hear it from the left rear, if turning right, you hear from the right rear. once you straighten up, it is gone, never does it if you are stopped and take off straight, and never does it while already in motion, only when stopped and turning. i had the rear end fluid topped off and an additive put in it, but no luck. any ideas??? thanks in advance.
Old Dec 27, 2007 | 11:52 AM
anfo's Avatar
anfo
Guesses but... bad wheel bearing, bad u joint, most likely - the wrong amount of friction modifier was put in the rear end.
Old Dec 27, 2007 | 11:20 PM
FTE Herman's Avatar
FTE Herman
I had what you describe, ended up being the posi clutches coming apart. I caught it just at the right time.
Old Dec 28, 2007 | 03:54 AM
rhino_160's Avatar
rhino_160
what did it cost as far as parts wise? and what can i expect from a mechanic?
claycomotrucks1991
6.2L V8
Sep 5, 2024 03:33 PM
torquemeister
Dec 8, 2018 06:53 PM
claycomotrucks1991
Oct 29, 2014 09:11 AM
wesayso
2004 - 2008 F150
Mar 21, 2011 05:21 AM
entomber
1978 - 1996 Big Bronco
Mar 7, 2004 11:11 PM
