Mr. 344
Old Dec 26, 2007 | 08:05 PM
Action4478's Avatar
Action4478
Mr. 344
Lets see who bites....
Old Dec 26, 2007 | 08:11 PM
tjbeggs's Avatar
tjbeggs
RICK!!!!!
Just trying to get me to condemn that new and improved CPS aren't you. You just want me to hammer all the people who are hoping and praying the new CPS is new and improved!!
Well I think Rick wants me to tell you all that after my first recall fix cam sensor failed 24 hours after it was installed I experienced a CPS hiccup on Monday which set a P0344 but its still too early to codemn the new sensor. I am certain the dealer cleared all the codes though when they installed the recall unit cause I checked them.
BTW- DO NOT and I repeat DO NOT GET YOUR CPS REPLACED UNLESS YOU ARE HAVING PROBLEMS WITH IT!!!!
Rick if this is not what your talking about then I look like a fool, but whats new!!
Old Dec 26, 2007 | 08:30 PM
Action4478's Avatar
Action4478
Originally Posted by tjbeggs
RICK!!!!!
No fools here ....
No disrespect intended...
Just bad luck....
Wasn't going in that direction...But you can do your part with a warning..
It makes me wonder if it was actually a safety recall.. especially if you are less safe after ?.....
Lots have stepped up , you just weren' t very lucky,,,
Maybe they thought it was my truck
Old Dec 26, 2007 | 08:36 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by Action4478
No fools here ....
No disrespect intended... None taken!!!
Just bad luck....
What was your direction??
I guess I need to stop hangin out with your if your luck is going to rub off on me! Maybe I need to get the Lucky 13
Old Dec 26, 2007 | 08:39 PM
Action4478's Avatar
Action4478
Lucky 13 is broke....
Old Dec 26, 2007 | 08:40 PM
tjbeggs's Avatar
tjbeggs
What??? DO you have a 344 hangin around??
Old Dec 26, 2007 | 08:42 PM
2 stroke man's Avatar
2 stroke man
could exessiv ecranking throw the old p0344?
Old Dec 26, 2007 | 08:43 PM
Action4478's Avatar
Action4478
Haven't checked ,,, but I bet I have more than that....
I guess I win.....
Just tell the water pump story.....
Old Dec 26, 2007 | 08:53 PM
tjbeggs's Avatar
tjbeggs
I guess I win.....
Whats it doing? or not doing?
2 stroke yes a CPS code can be caused by cranking without starting.
Old Dec 26, 2007 | 08:54 PM
tjbeggs's Avatar
tjbeggs
maybe it will pull an ethernet card!! remove, install, works!!
Old Dec 26, 2007 | 08:56 PM
Action4478's Avatar
Action4478
I have a spare in the cabinet....
