Voltage Regulator
Old Dec 26, 2007 | 07:55 PM
cornfedp's Avatar
cornfedp
Voltage Regulator
Ok, Ive done some searching on the instrument panel voltage regulator, but if it was bad wouldnt the temp gauge not work right as well? Right now only my fuel gauge doesnt work, and I just have fuel and temp for gauges. 1971 F100.
Old Dec 26, 2007 | 10:13 PM
vanwho's Avatar
vanwho
Sounds like your gas tank sending unit could be bad. Try this quick test. Turn ignition either to the acc or on position, pull the sending unit lead and ground it. If you see the needle make a full sweep when it is grounded, your sending unit is bad. If it doesn't, you may have other issues. I'm sure some of the others will chime in and offer other suggestions. Hope this helps you find a starting point.
Old Dec 27, 2007 | 09:37 PM
cornfedp's Avatar
cornfedp
Ok, I did that and as soon as I grounded it the gas gauge went to full. I will be ordering the sending unit from Mac's next week I guess. Thanks for the info.
Old Dec 28, 2007 | 08:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TZ9275G .. Fuel Tank Sender - In Cab Tank / Fits: 1961/77 F100/350 & F500/750
Still available from Ford
From FTE sponsor Y2KFORDPARTS (Millennium Ford-Seattle) Ford suggested retail price: $83.40 / FTE member net $60.05
From FTE sponsor DIRECT FORD PARTS (Gaudin Ford-Las Vegas NV) Ford suggested retail price: $83.40 / FTE member net price: $58.95
Both the above sponsors links are on the forum main page - refresh till they appear.
ihc1470
Nov 19, 2014 12:17 PM
Rusty_S
Electrical Systems/Wiring
Mar 29, 2013 07:02 PM
fordtrck1955
20
Dec 31, 2008 06:29 PM
pollock
Bronco II
Jun 29, 2005 02:37 PM
jeffreysw
Aug 11, 2002 04:05 PM
