Door Locks
Old Dec 27, 2007 | 04:55 PM
bob_351's Avatar
bob_351
1 key per vehicle? I thought the door and ignition key werent supposed to match at least not back then. Mine dont match and nethier does the ones on a 1990 mustang ive driven. In both cases the door key has a round handle and the ignition is square, Is this just a coincidence or maby its a canadian thing?
Old Dec 27, 2007 | 05:38 PM
Franklin2's Avatar
Franklin2
GM was big on the two key thing. The Ford trucks I have owned used one key till the ignition tumbler fell apart, and then I had two keys, one for the new ignition tumbler, and the old one for the doors and the hood latch.
Old Dec 27, 2007 | 05:41 PM
Franklin2's Avatar
Franklin2
Originally Posted by jowilker
You can always call around to the locksmiths to see what they would charge. I like the one key per vehicle approach.
Can you pull the inner panels and get to the cylinders? You can pull them and take them to the lock smith yourself if you are short on coins.
John
Don't even need to pull the panels. Open the door and look at the door jamb on the door, about the same height as the key tumbler. You will see a rectangle piece of metal. Pry this metal piece out, and the tumbler will come out.
Old Dec 27, 2007 | 06:01 PM
86F150302's Avatar
86F150302
Ok ill call a locksmitch tomorrow and see how much it will cost.
Old Dec 28, 2007 | 10:25 PM
86F150302's Avatar
86F150302
http://www.lmctruck.com/icatalog/fd/0017.asp
is 41 what i need?
Old Dec 29, 2007 | 01:56 AM
Sycostang67's Avatar
Sycostang67
Yeah, thats pretty much what you would get at a parts store too. Locks, keys, clips, and gaskets for the same price most likely.
Old Dec 29, 2007 | 05:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980/81 F100/350 keyed alike door/ignition lock cylinders
As original: The door/ignition keys matched from (at least) 1941 thru 1981.
When purchased new, all Ford vehicles came with two sets of keys.
Along with the keys were round tags that had the key code(s) on them.
Dealers were supposed to write the key codes into the owners manual.
The codes begin with: FA for square headed keys / FB for round headed keys.
> > Your truck originally was "all keyed alike" except for the glovebox lock. < <
1980/81 F100/350
E1TZ-1022050-A .. Door/Ignition Lock Set-Keyed Alike (without locking hood cable) STILL available from Ford.
From FTE sponsor DIRECT FORD PARTS: Ford suggested retail price: $86.37 / FTE member net price: $61.04
E1TZ-1022050-D .. Door/Ignition Lock Set-Keyed Alike (with locking hood cable) ~ OBSOLETE ~
With locking hood cable. The same key that operated the doors/ignition also locked/unlocked the hood cable.
btw: old geezer parts guys that have cut..by hand held key cutters, 1000's of keys, can eyeball any key and read the cuts.
The cuts are numbered 1 thru 5, with 5 being the deepest. The tumblers inside the cylinders match the cut of the keys.
Car thieves can also read keys.
Do NOT leave keys (this includes house and other types) lying around, or take them out of your pocket in public places.
One glance is ALL it takes!
Old Dec 29, 2007 | 06:41 AM
jowilker's Avatar
jowilker
Originally Posted by 86F150302
is 41 what i need?
Wouldn't surprise me if that same set isn't cheaper at your favorite parts house.
This will still have you using two keys for the truck, a locksmith will have to rekey them to use just one.
John
Old Dec 29, 2007 | 07:01 AM
fellro86's Avatar
fellro86
My 86 and my dad's 84's all use a round key for the doors, and square for the ignition, so I don't see this as a problem, since they are factory set up this way...
Old Dec 29, 2007 | 07:57 AM
NumberDummy
Wouldn't surprise me if that same set isn't cheaper at your favorite parts house.This will still have you using two keys for the truck, a locksmith will have to rekey them to use just one. John
Woodn't surprise me either.
"Da Dummy" mainly listed the numbers to show that Ford used "keyed alike" ign/door lock sets thru 1981. Then "Da Dummy" checked online to see if either was available.
Old Aug 28, 2008 | 10:32 AM
pro3qtr's Avatar
pro3qtr
Motorcraft still sells the ignition set for $27 list. Just got a set yesterday.
SW-1609 (EOTZ-11582-A)
Hope that helps !
Old Aug 28, 2008 | 05:20 PM
Fordzilla80's Avatar
Fordzilla80
Hope that helps !
I'm really suprised nobody mentioned J-Yard..With my truck,I went around to a couple of trucks and looked for keys.If it had the door key,I tried it in the locks.It might take a couple different trucks,but I found mine within 10 minutes.When I went to pay, the lady said 2 bucks for all....can't complain...
Old Aug 28, 2008 | 05:39 PM
  #28
uncle.stosh's Avatar
uncle.stosh
I personally didn't say Junk Yard, cause that's a given for me.
I get EVERYTHING from the Junk Yard..........
Old Aug 28, 2008 | 06:37 PM
  #29
Fordzilla80
True.I'm the same..with looks wise..anything mechanical,I get new.But interior/body I get from the jyard.There's no replacement for factory ford sheetmetal...
Old Aug 28, 2008 | 07:59 PM
  #30
joestratton1's Avatar
joestratton1
buy the lockset from the parts store. open your door and pull the keeper out (shiny flat thing 1-1/2" X 1/4" on inside of door) with needlenose. use a screwdriver or something to keep the rod from falling into door remove the C - clip and install new lock. can be done faster than it took me to type this.
