4x4 not working
Old Dec 26, 2007 | 04:23 PM
Rainman87's Avatar
Rainman87
4x4 not working
hey so im new to this site, and hope that someone out there has some ideas. my 4X4 is a pushbutton, and the switch has power but the 4X4 wont engage, in fact it is not doing anything at all. does anyone have any ideas on what the problem could be. by the way it is a 1995 f150. thanks!
Old Dec 26, 2007 | 04:32 PM
breisr's Avatar
breisr
probably your automatic hubs
Old Dec 26, 2007 | 05:06 PM
danr1's Avatar
danr1
More likely to be the electric shift motor if nothing happens rather than the hubs, if the transfer case doesn't shift into 4wheel than the hubs won't do anything.
But first lets try to narrow down what does happen, does the 4x4 light come on? Does it flash? Tell us exactly what it does do or doesn't do. Please be very specific.
Oh and include in that anything you hear when you push the button.
Old Dec 26, 2007 | 07:05 PM
Rainman87's Avatar
Rainman87
4X4 not working
When i push the 4x4 button nothin happens at all. no flashing light not lights at all. there are also no sounds coming from the tranny or transfer case.
Old Dec 26, 2007 | 08:12 PM
danr1's Avatar
danr1
Ok, first test the control module.
It may be behind the passenger side kick panel or behind the instrument panel on the right hand side, behind the wiring harnesses.
If you can't find it post back.
Control Module Self-Test
1. Remove the five-wire connector and the eight-wire connector from the bottom of the electronic control module.
2. Turn the ignition switch to the RUN position.
3. Activate the self-test switch located on the module and note the result:
* A flashing indicator lamp (approximately one flash per second) indicates that the control module is functioning properly.
* A steady indicator lamp indicates that the control module is inoperative and must be replaced.
