Two strange questions
Old Dec 27, 2007 | 01:25 PM
Aztrainer's Avatar
Aztrainer
Originally Posted by King Triton
Hey! I have a question too. Why is the most confusing day in Detroit,,,Fathers Day?
Mother's Day - For those that do not live with mommy
Grandparents Day
Parent Teacher Confrence Day
Thanksgiving
Tax Day
I think there could be more.....
Old Dec 27, 2007 | 02:14 PM
FLgargoyle's Avatar
FLgargoyle
I was following an old farm truck, and every mile or so he would stop and whack the sides of the truck with a stick. After this happened a couple times, I got out and asked him what he was doing. "Well, I gots me a 1 ton truck, but I gots 2 tons o' chickens. So I gots to keep half of them flyin' in the air." Will his technique work?
Old Dec 27, 2007 | 03:36 PM
Aztrainer's Avatar
Aztrainer
Only over bumps....
That is almost as good as what weighs more
1 . A ton of Bricks
or
2. A ton of feathers
Old Dec 27, 2007 | 04:15 PM
Nitramjr's Avatar
Nitramjr
Originally Posted by Aztrainer
No, that is what I was stating....
AND OH NO YOU DID NOT>>>>>>>>>>>>>
So you are stating that the rpm/angular velocity of the tip of an aircraft propeller or any other spinning mass is different than it is close to the hub?
I don't care if the radius of the spinning object is 100 miles, the tip will rotate at the same number of revolutions/time that the center will.
Please, one last chance, tell me you are kidding.....
Old Dec 27, 2007 | 04:24 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I think he's talking about the treadmill plane.
Old Dec 27, 2007 | 04:48 PM
crehberg's Avatar
crehberg
I think you guys have WAAAAAAAAAY too much time on your hands.
Ok, now I'll add a question.....I keep seeing in peoples' sigs a box about overclocking to fight cancer. Anybody got a link where maybe I can get in on the fun????
Old Dec 27, 2007 | 04:58 PM
Aztrainer's Avatar
Aztrainer
No, I agree with you that the rpm at the hub and the tip are the same.
Old Dec 27, 2007 | 05:32 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Traderjoe28
The contact patch instantaneous forward velocity is zero, otherwise the tire would be skidding on the ground.
OK [QUOTE=Tradejoe28]The center of the axle velocity is the car's speed forward,QUOTE] I'll buy that
and the top of the tire tread is twice the car's forward speed.
I can't wrap my brain around this part. Due to different size tires on different vehicles, this cannot possibly be a constant .
Last edited by SteveBricks; Dec 27, 2007 at 05:36 PM. Reason: miss-placed quotation
Old Dec 27, 2007 | 06:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
what weighs more
1 . A ton of Bricks
or
this one is easy. a ton of 6000lb/square inch density concrete.
Old Dec 27, 2007 | 07:13 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Go up and read my post above... ain't gonna explain it again. 'Cept to say that the hub and blades ARE spinning the same RPM. But the speed of the hub is much slower than the outside edge of the prop or rotor blade or any other object with a hub and something larger in diameter attached to it.
Go outside and do my experiment.
If the outside edge of a rotor moved the same speed as the hub, there'd be some serious warpage involved at some time or another.
It's elementary, my dear Watsons.
And, the question was about speed..not Revolutions Per Minute... two different factors.
Old Dec 27, 2007 | 07:26 PM
bigrigfixer
The Pacifier
You mean to say some people aren't getting it?
RPM is the same no matter what.
MPH will be different no matter what.
How about you tie a shotput to a rope, hold on to the rope, and spin yourself around in one spot. You and the shotput are ROTATING at the same rate of spin. But the shotput is TRAVELLING at a different rate of speed.
Old Dec 27, 2007 | 07:32 PM
Jimmy Dean's Avatar
Jimmy Dean
He is correct, the very top of the tire will betraveling at twice the vehicles velocity, the contact patch at 0 mph, and the axle at velocity...this is supposing you are under traction as well
To help wrap your head around that.
There are 2 basic types of velocity.. teh velocity you normally think of, linear velocity, and then there is angular velocity.
Now, the angular velocity of the tire, any point on it, the rim, the hub, is the same. The linerar velocity of the assembly is of course, the same, however that is an average velocity of all the parts.
Since the assembly is also rotating, the combined velocity, both angular and linear, at any given point in time, will not be similiar between two points of differant radii from the center, or even a differant angle from a given starting position of 0 degrees.
Now, to help in English.
a 30 inch street tire, like on my '02, and a 44 inch mudder, like what will be on my future bronco..
in order to go 1320 inches...um 110 feet?...the 30 incher has to rotate 44 times, while the 44 inch tire only has to rotate 30 times. now, if the two trucks are traveling at the same speed, obviously the 44 inch tire is rotating much slower.
Therefore, the 44 incher has a much lower angular velocity. however, it is maintaining the same linear velocity....btw....tanks and their treads are MUCH better example of this....and I dont know really whre to explain from here, except that a wheel powered vehicle moves fowards by placing more rubber/tread in front of the last rubber tread it laid down....much like how you put one foot in front of the other to move foward, except taht this is continuos.
now disregarding tire width, since we will pretend like that doesnt matter right now, no matter the size of the tire, in order to move foward 12 inches, it has to put down 12 inches of rubber, you with my crude explanation? well, if it needs to put down that 12 inches in a second, than at any location along the surface of the tire, the tire will be moving foward 12 inches of rubber in that second, now, if the tire is already moving foward at 12 inches / second, then if you look at the top of tire, it still needs to pass 12 inches of rubber / second to keep up the speed, add in its actual velocity and BAM! 24 inches / second instantaneous velocity.
Old Dec 27, 2007 | 07:39 PM
  #28
firstrider's Avatar
firstrider
Where is lostmybeer when you need him ? I think that is what happened to khadma . Have 2 questions for khadma to ponder .Do you think the earth is getting heavier or lighter and does air have mass ?
Old Dec 27, 2007 | 07:40 PM
  #29
Nitramjr's Avatar
Nitramjr
Glad someone agrees with me....
Old Dec 27, 2007 | 07:41 PM
  #30
SteveBricks
FTE Emeritus
I think I stand corrected?
