Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Ford Gifts
Old Dec 28, 2007 | 10:02 PM
  #31
preppypyro's Avatar
preppypyro
Your lucky morris your 6 liter is a tad faster! I will just be taking one truck though. Maybe a parts one to. Gotta love a heated garage Chris!
Old Dec 28, 2007 | 10:04 PM
  #32
Dustin1690's Avatar
Dustin1690
Thats a cool present preppy...
Old Dec 29, 2007 | 12:49 AM
  #33
Fomoko1's Avatar
Fomoko1
Hopefully all the others find good homes too preppy, hate to see them rust further away..
Old Dec 29, 2007 | 06:09 AM
  #34
96sherm's Avatar
96sherm
is he looking to get rid of more than one or two trucks Prep?? should we be seriously interested??
What are you using to heat your shop chris?? gas, wood??
Old Dec 29, 2007 | 08:52 AM
  #35
preppypyro's Avatar
preppypyro
Unfortunatly most of them will end up rusting away. My uncle likes collecting that stuff. In the spring when i go get a truck i am gonna take more pics and if someone is seriously interested in something i will ask.
Old Dec 29, 2007 | 02:03 PM
  #36
effie_man's Avatar
effie_man
right now a 220V electric construction heater
Old Dec 29, 2007 | 05:06 PM
  #37
96sherm's Avatar
96sherm
that'll run up a bill if its going steady!! are you planning for a gas system??
Old Dec 29, 2007 | 06:08 PM
  #38
Fomoko1's Avatar
Fomoko1
My son uses a 220 Volt heater in his 28 X 36 X 10 shop and I too thought it would be too expensive but it`s not bad at all with his fairly new, air tight and well insulated shop.
Mine diffinitely wouldn't work.....
Old Dec 29, 2007 | 08:17 PM
  #39
effie_man's Avatar
effie_man
ya we went pretty crazy with the inso and poly, im expecting it to be maybe 70-100$ more a month, which isnt too bad and its only 6 months out of a year
Old Dec 29, 2007 | 08:55 PM
  #40
96sherm's Avatar
96sherm
i think i heard that the 4800watt construction heaters run about 5 bucks a day. if you don't have it on all day every day thats not too bad.
Old Dec 29, 2007 | 10:22 PM
  #41
effie_man's Avatar
effie_man
ya and mine runs all day till the slab is warmed up then i can lower it down to maintain like 0-5 degrees then turn it up when i want to work in there
Old Dec 30, 2007 | 07:31 AM
  #42
96sherm's Avatar
96sherm
would have been nice to put in-floor heat in there. its not that expensive to set up and boy is it nice!!!
Old Dec 30, 2007 | 09:25 AM
  #43
preppypyro's Avatar
preppypyro
When i build my shop i would like to do radiant floor heat. I dont know much about it though including the cost.
Old Dec 30, 2007 | 10:02 AM
  #44
66gpw's Avatar
66gpw
The intial cost of installation is very expensive, But in the long run the heating costs are lower. Just maintenance on pumps and heat exchanger. You can install it your self. You need to buy the material and lay out a grid for the lines to run to heat the floor. Less likely hood of floors cracking from ground heave. The whole place stays warm. So working on your tuck near the floor is nice it is always warm.
In floor heating is a excellant choice. Just the dollars for first installing.
Do some research on it first. The other option is look into solar or wind power sources for heating also. I'm considering a wind power for heating my quonset besides the gas to help cut down my costs. Again the initial start up is expensive.
Old Dec 30, 2007 | 12:05 PM
  #45
Fomoko1's Avatar
Fomoko1
Hanks`s Service has a large outside wood burning boiler to heat all of his shops and house. His down side is that he has to buy most of the wood.
