Stuck in 4wd.
PINPOINT TEST B: THE VEHICLE DOES NOT SHIFT BETWEEN A4WD AND 4WD MODES PROPERLY
Note:
Complete the entire pinpoint test related to the symptom before replacing the GEM.
² B1: CHECK THE IGNITION STATES
² B2: RETRIEVE THE RECORDED GEM DTCS FROM BOTH CONTINUOUS AND ON-DEMAND SELF-TESTS
² B3: CHECK THE 4H INDICATOR
² B4: CHECK THE 4L INDICATOR
² B5: MONITOR THE MODE SWITCH GEM PID 4WD_SW
² B6: CHECK THE MODE SWITCH
² B7: CHECK CIRCUIT 780 (DB) FOR OPEN
² B8: CHECK CIRCUIT 780 (DB) FOR SHORT TO GROUND
² B9: CHECK CIRCUIT 780 (DB) FOR SHORT TO POWER
² B10: CHECK CIRCUIT 682 (DB) FOR OPEN
² B11: CHECK CIRCUIT 682 (DB) FOR SHORT TO POWER
² B12: MONITOR THE GEM PIDS MTR_CCW AND MTR_CW — GEM ACTIVE COMMAND CW/CCW ON
² B13: MONITOR THE GEM PIDS MTR_CCW AND MTR_CW WITH THE GEM ACTIVE COMMAND CW/CCW SET TO ON
² B14: CHECK THE VOLTAGE TO THE TRANSFER CASE SHIFT RELAYS COILS — CIRCUIT 704 (DG/LG)
² B15: CHECK CIRCUIT 781 (OG/LB) FOR OPEN
² B16: CHECK CIRCUIT 782 (BN/WH) FOR OPEN
² B17: CHECK CIRCUITS 781 (OG/LB) AND 782 (BN/WH) FOR SHORT(S) TO GROUND
² B18: CHECK CIRCUIT 782 (BN/WH) FOR SHORT TO POWER
² B19: CHECK CIRCUIT 781 (OG/LB) FOR SHORT TO POWER
² B20: CHECK THE TRANSFER CASE SHIFT RELAYS COILS
² B21: CHECK THE VOLTAGE TO THE TRANSFER CASE SHIFT MOTOR — GEM ACTIVE COMMAND CW/CCW ON
² B22: CHECK THE VOLTAGE TO THE TRANSFER CASE SHIFT RELAYS SWITCH SIDE — CIRCUIT 704 (DG/LG)
² B23: CHECK THE VOLTAGE TO THE TRANSFER CASE SHIFT MOTOR — GEM ACTIVE COMMAND CW/CCW OFF
² B24: CHECK CIRCUITS 777 (YE) AND 778 (OG) FOR SHORT(S) TO POWER
² B25: CHECK CIRCUITS 777 (YE) AND 778 (OG) FOR OPEN
² B26: CHECK CIRCUIT 777 (YE) FOR OPEN
² B27: CHECK CIRCUIT 778 (OG) FOR OPEN
² B28: CHECK THE GROUND TO THE TRANSFER CASE SHIFT RELAYS — CIRCUIT 57 (BK)
² B29: CHECK THE CONTACT PLATE SWITCHES — MONITOR THE GEM PIDS PLATE_A, PLATE_B, PLATE_C, AND PLATE_D
² B30: MONITOR THE GEM PID PLATE_A FOR OPEN
² B31: CHECK CIRCUIT 771 (VT/YE) TO THE CONTACT PLATE SWITCH A
² B32: CHECK CIRCUIT 771 (VT/YE) FOR SHORT TO GROUND
² B33: CHECK CIRCUIT 771 (VT/YE) FOR OPEN
² B34: CHECK CIRCUIT 771 (VT/YE) FOR SHORT TO POWER
² B35: CHECK CIRCUIT 762 (YE/WH) FOR SHORT TO POWER
² B36: CHECK CIRCUIT 762 (YE/WH) FOR OPEN
² B37: MONITOR THE GEM PID PLATE_B FOR OPEN
² B38: CHECK CIRCUIT 770 (WH) TO THE CONTACT PLATE SWITCH B
² B39: CHECK CIRCUIT 770 (WH) FOR SHORT TO GROUND
² B40: CHECK CIRCUIT 770 (WH) FOR OPEN
² B41: CHECK CIRCUIT 770 (WH) FOR SHORT TO POWER
² B42: MONITOR THE GEM PID PLATE_C FOR OPEN
² B43: CHECK CIRCUIT 764 (BN/WH) TO THE CONTACT PLATE SWITCH C
² B44: CHECK CIRCUIT 764 (BN/WH) FOR SHORT TO GROUND
² B45: CHECK CIRCUIT 764 (BN/WH) FOR OPEN
² B46: CHECK CIRCUIT 764 (BN/WH) FOR SHORT TO POWER
² B47: MONITOR THE GEM PID PLATE_D FOR OPEN
² B48: CHECK CIRCUIT 763 (OG/WH) TO THE CONTACT PLATE SWITCH D
² B49: CHECK CIRCUIT 763 (OG/WH) FOR SHORT TO GROUND
² B50: CHECK CIRCUIT 763 (OG/WH) FOR OPEN
² B51: CHECK CIRCUIT 763 (OG/WH) FOR SHORT TO POWER
² B52: CHECK THE SHIFT MOTOR
² B53: CHECK CIRCUIT 994 (WH) FOR OPEN
² B54: CHECK CIRCUIT 994 (WH) FOR SHORT TO GROUND
² B55: CHECK CIRCUIT 994 (WH) FOR SHORT TO POWER
² B56: CHECK CIRCUIT 994 (WH) FOR OPEN
² B57: CHECK CIRCUIT 994 (WH) FOR SHORT TO GROUND
² B58: CHECK CIRCUIT 994 (WH) FOR SHORT TO POWER
I did get locked in 4L a couple of times before I had to replace the electric shift motor at the transfer case-----and this happened just in the cranking process (without shifting the transfer case switch).
I got "unlocked from 4L" by disconnecting the battery cable momentarily (apparently let the computer reset itself???).
The dealer suspected the GEM module-----problem turned out to be the shift motor.
Delta Dirt
Mississippi
