Reverse Lights Stuck On!
Old Dec 25, 2007 | 01:43 PM
nrgman's Avatar
nrgman
Unhappy Reverse Lights Stuck On!
My reverse lights stay on in all gears including park when truck is running or ignition is on, also my back-up sensors are not working and can not be turned on from dash button and warning buzzer stays quiet. The truck is equipped with a slip-in sanding box used for snow removal service. The sander box over hangs rear bumper which trips the back-up sensors. The system was working normaly up till now can any one point me in the right direrection?
2005 F350 King Ranch 6L diesel
Old Dec 25, 2007 | 07:40 PM
Franklin2's Avatar
Franklin2
You have a "digital transmission range sensor" on the left side of the tranny if you have an automatic. You have a "reversing switch" on the tranny if you have a manual. Power comes into these switches on a lightblue/pink wire and leaves to feed the backup lights and trigger the reverse warning system on a black/pink.
I think there is something wrong with this switch, or if these wires are bundled together going to the tranny, they may have melted together from getting on the exhaust, or some other scenario like that.
Big-Red-Lariat
2004 - 2008 F150
18
Jan 19, 2015 05:15 PM
NorEasterMA
Jan 17, 2015 06:37 AM
Powerstrokin_350
Apr 17, 2012 07:48 AM
TheBludgeon
May 24, 2010 09:04 PM
illuminance72
Electrical Systems/Wiring
Mar 4, 2004 10:14 PM
