Factory Ignition Coil
Old Sep 26, 2000 | 01:54 AM
hood's Avatar
hood
I have a 81 F-150 4.9L with 187,000 miles. I am the original owner so I know everything under the hood is stock. The wires and plugs are new. I get around 15-16 MPG (with 92 octane) in the summertime and 12-14 MPG wintertime driving. Anthing less then 92 octane cause a nasty spark knock. The carb is a rebuilt 1 BBL. With the coil being 19 years old could it be slowly breaking down causing a decrease in performance?
Any suggestions on the coil would be very much appreciated here.
Old Sep 26, 2000 | 10:44 AM
PAUL_2's Avatar
PAUL_2
That coil should be put up on the mantle when it does die .... Its hard to say with coils , sometimes they just die & then you have some that last as long as yours has been working . Its possible the spark knock is coming from carbon buildup on the tops of the pistons . The compression is raised from the carbon buildup so when you use a lower octane you get the knock . You might try using some Chevron Techron or other quality products designed to remove carbon etc to see if that helps .
Old Sep 27, 2000 | 09:53 AM
rlbertrand's Avatar
rlbertrand
Get a Blaster coil.
Old Sep 28, 2000 | 01:57 PM
moley's Avatar
moley
