Header COATING Questions/Recomendations
Old Dec 24, 2007 | 11:44 AM
LARIAT 85's Avatar
LARIAT 85
1985 F150 with carbed 4-barrel 302 and Duraspark II conversion. My next step is headers and exhaust system...
I have a selection of painted, stainless, thermal, and ceramic headers. Which ones would you recommend, and why?
And, if I were to go with *ceramic* headers, would my air cleaner "hot air stove" still be effective?
Old Dec 24, 2007 | 02:52 PM
Franklin2's Avatar
Franklin2
I have never had any of the fancy coatings. I have always bought the painted, and it lasts about 30 minutes after you get the engine running. Then it's rust from then on out. The last set I bought, I took paint remover and removed the factory paint, and then painted them with the duplicolor high heat paint, and it was still on there about 4 months later when I sold the truck, except the places I missed which start to rust.
Old Dec 24, 2007 | 03:36 PM
turret_plug's Avatar
turret_plug
Ditto..... If you have the extra money to spend try to get the ceramic, they will blue a little, but not bad. I did the same as franklin, i just stripped them with a grinder brush and used some VHT crinkle finish paint, and they are still good, and I live in washington state, and it always rains here, and still no rust, and for the love of creatures big and small, dont use the shorty headers, use long tube, more HP and better flow..... shortys dont give you as much noticeable change
Old Dec 28, 2007 | 04:21 AM
ozstang65's Avatar
ozstang65
I've just had the complete system in my '82 F100 ceramic coated. (351C, extractors into a single 3") I plan on doing a lot of towing so I wanted to keep engine bay temps as low as possible. I haven't had it running yet so I can't give any definitive results. Being coated inside and out, it will supposedly add 5+ years to the life of the system and I'm hoping that the lower engine bay temps add extra life to all the components in there, especially the starter motor.
Not cheap though....
