Roll Bar!!
Old Dec 24, 2007 | 11:05 AM
Ranger4x4's Avatar
Ranger4x4
Exclamation Roll Bar!!
I just purchased a roll bar for my 95 Ranger 4cyl. Right now I am sanding the old paint off and getting ready to paint it flat black. My question is how do you guys that have a roll bar and lights on top wire up your lights. Do you run your wires to the car's battery or do yall set up a seperate battery to power the lights on the roll bar? I need some ideas here as im coming closer to mounting my roll bar onto my truck.
P.S. Pictures Are A PLUS++++++
Old Dec 24, 2007 | 11:40 AM
RangerPilot's Avatar
RangerPilot
Heya Ranger4x4,
I can only be so helpful with this, because I've never had a roll bar. But on my Ranger I did have four lights located behind the grille/in the bumper, so I've done the aftermarket lights thing.
I ran a 5-ga common wire from the battery for about a foot where I mounted an 80-amp main fuse. From there I ran another couple of feet of 5-ga wire to a splitter which set that down to two 8-ga wires. I ran one of those to the cab of the truck, through another splitter, where I installed a switch, then ran a wire to the lights themselves. I used 14-ga wire to run to the actual lights. After doing that, I grounded them all properly, and they worked great.
My only issue was at idle, the lights could pull the engine down some because they pulled so much juice.
Since you're using a roll bar, they can probably ground through the bar itself. I'd imagine all you'd have to do is run a wire to the switch in the cab, then a 12V wire to the battery itself, making sure to use a fuse in between, and you'd be good.
Hope it helps.
Bigbruce
33
Dec 12, 2013 03:30 PM
DanTheMan221
2010 - 2014 Ford SVT F150 Raptor
30
Nov 21, 2013 10:00 PM
NWcountry
Appearance & Dress-Up
Jan 24, 2005 08:25 PM
03 Ranger FX4
Jan 9, 2004 01:35 PM
sublimecharger68
Dec 8, 2002 08:54 PM
