Sponsored by: Real Truck
2nd cracked trans
Old Dec 24, 2007 | 10:18 AM
sbc_prod's Avatar
sbc_prod
Question 2nd cracked trans
Last night I cracked the 2nd 4R100 on my F250 5.4L. They keep cracking right in front of the transfer case right over the reverse clutch. (Not on the seperate part that connects to the transfer case but on the actual trans. housing.) Its a vertical hairline crack. The first time this happened it cracked all the way around and the transmission actually broke in two. I was driving down the interstate at about 75. I got to where I was going but when I went to leave it wouldn't shift into reverse. I got out and looked and there was a pool of fluid underneath. Anyone have any ideas what may be causing this? Or ever heard of this happening to anyone else? I can't afford to keep buying transmissions...
Thanks
Ray
Old Dec 24, 2007 | 11:07 AM
BillyBob69's Avatar
BillyBob69
Sounds like could be incorrect mounting causing stress on the housing. I know it sucks having to get it done again...but I would get a second opinion before going back to the same place as before. Also, search on the main page of this forum. There should be a link to TSB's and recalls. Maybe there is something there about your problem.
Old Dec 24, 2007 | 02:30 PM
bigblock_drock's Avatar
bigblock_drock
What the hell are you doing with the truck??
but that sums it up for the most part
Old Dec 24, 2007 | 02:41 PM
riggz's Avatar
riggz
Any mods to the truck that might increase the stress on the tranny?
Old Dec 24, 2007 | 02:57 PM
Asupreme1's Avatar
Asupreme1
Its a 5.4L. How could the trans be stressed?
Old Dec 24, 2007 | 03:40 PM
Hellrazor1's Avatar
Hellrazor1
It is stressed out wishing it was a diesel...
Old Dec 24, 2007 | 03:47 PM
99f350sd's Avatar
99f350sd
What year? 05's had internal issues that caused cracks with trucks with plows.
Dick
Old Dec 24, 2007 | 04:22 PM
sbc_prod's Avatar
sbc_prod
usage of truck
Its a '99. the only mod is a different hood and bigger tires. It was like that when i bought it. I mainly just drive it around town hauling building materials. Yesterday was the first time its been on the interstate since the new trans. I've put exactly 438 miles on it since it was last fixed. I don't really think I can blame the trans shop since it's cracked in exactly the same spot...but what is causing this?
Ray
Old Dec 24, 2007 | 04:38 PM
ameinig's Avatar
ameinig
Is it cracking ahead of or behind the trans mount? Are the motor mounts moving and putting too much stress on it?
Old Dec 24, 2007 | 06:09 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Thats a good one
Old Dec 24, 2007 | 11:12 PM
redford's Avatar
redford
FTE Leadership Emeritus
Have the engine block checked. It sounds like the mounting surface for the transmission isn't square to the thrust line of the engine.
Old Mar 9, 2010 | 03:49 PM
luisfer8724's Avatar
luisfer8724
Cool Thread resurrection
I have A 1999 WITH A 6.8L V10. Bought it 2 months ago took it to the beach and returned with no transmission fluid. when they took it apart we found that the extension in between the transmission and the transfer case had been JV welded and it had let out all the transmission fluid and burned the tranny. I got a used transmission from a junkyard put it in the truck and got stranded at the beach. The oil leaked out through what appeared to be a loose screw. towed it to the shop when they took apart the oil pan it turned out it was fractured. they ttok the tranmission down it turned out to be fractured all the way around. The only thing holding it up was the oil pan. This time it was the actual transmission that was cracked not the extension. I have to get another one but I dont want to put it in until i find what the cause was. Any Ideas???
Old Mar 9, 2010 | 05:12 PM
ken kenmnedy's Avatar
ken kenmnedy
ok you guys are scare,in me here ....what kind of trucks are these long wheel base ,short wheel base,lifted ,big tires..... I work the **** outa this truck now I am gonna need some hoist time
Old Mar 9, 2010 | 05:17 PM
99f350sd's Avatar
99f350sd
As far as I know this is really rare to crack a superduty tranny.. The 05 early ones had issues..Hasn't been one of those issue's that rings a bell.
Dick
Old Mar 9, 2010 | 05:19 PM
luisfer8724
broken tranny
Mine is stock as far as I can tell.
