FT manifolds on an FE
Is it possible to use the center dump FT manifold on an FE motor, provided that the exhaust crossover has been welded up? The only thing that concerns me is if they'll clear the motor mounts. I like the looks and flow of the ram's horns a lot better than the stock FE logs.
One more question, the U-haul pickups used the 330 MD, what manifolds did they use? Anyone have a picture of them?
Sam
Sam
Well, looks like I'll just have to pickup a set and give it a shot! I talked with my machinist about it and he likes the idea.
I guess it depends on how tight the exhaust shop can bend that pipe!
EDIT: I was just looking at some pictures, and is it just me, or are are the motor mounts more toward the front of the block, and not dead center? My motor is at the machine shop right now, otherwise I'd go out and look.
Sam
Sam
I guess you'll need to be the guinea pig
Josh
Let's just say it was an expensive lesson well learned.
I haven't touched them since.
Not to hijack the thread, but I learned years ago that the orange filters are no good. Three cars in one week came in my shop with no oil pressure. ....zero. They all had orange filters. I took them off and put a WIX on them and topped off the oil. That's all I did. Oil pressure instantly bounced back to normal. If your by-pass is stuck and you run a Fram, it WILL clog and you'll lose oil pressure. Like the Hardee's commercial says, "That's just the way it is."
Let the guinea pigging begin! In other words, I tracked down a manifold.
As you can see in the first picture, the dump isn't perfectly centered. That might cause some issues, nothing too big, but something to think about.
My "test fit" says I'll probably have to modify the motor tower, but other wise it should fit the passenger side. This weekend (or whenever I over this stinkin cold) I'll pull my current manifolds and do a proper test fit.
Sam
P.S. I got my 390 back, it's in and running good! And I asked my machinst what oil filter I should run: "ANYTHING but a Fram!" is what he said! So I got some good wix filters for it at carquest. They're much better, (and cheaper!) than the Fram.
Sam
