Hi all, it's been quite some time since I have posted here in the X forum, but had something happen this morning and thought I’d ask the experts. I'll give a full account on what I did up to the event. Vehicle: 2000 X 2wd/V10 110,000 miles. The temp outside was about 30 deg. had minimal ice crystals on the windshield, turned the wipers on high to clear it, which it did after 10 seconds or so. Turned the heat on (fan on med), sat for a minute to let the engine warm a bit then backed out and headed up the street. Just before the stop sign
(maybe 1/8 mile), I smelled something funny, then saw smoke starting to come out of the vents, most heavy on the driver side next to the door. Pulled over, left the engine running, shut the fan off and jumped out. That’s when I noticed more smoke coming from the plastic outside inlet vent in front of the windshield. Again, most the smoke was coming from the side of the vent (not the middle). I then reached in and turned the climate control to off and also shut the engine off. Everything stopped smoking within a minute. Checked around but couldn’t find anything. Started the engine back up but didn’t touch the climate controls and nothing happened. Decided to go ahead and drive to 7-11 for my morning coffee and the store to pickup some food. Didn’t turn the climate controls back on until I got home, nothing happened.
I'm going back out to try and see what the problem was, but thought I would post a question to see if this has happened to any other X's?<O Sorry about the boring details.<O Thanks<O
Sorry 71-, should have posted the smell. It seemed to be more like plastic of what I could tell, unfortunately my sniffer is all jacked up as I am just getting over being sick and am still conjested. Did a little investigating and think I narrowed it down.
Here is what I did and found:
Started the engine and turned the heat and fan on high, nothing! Pulled the driver side (outside in front of windshield) vent cover and guess what is under it? The wiper motor! thought hmmm... I'll try the wipers. they work great on high and low, but on intermittent they will stop and go at any given point in the sweep!
So here's a question, could this be a bad wiper motor? or maybe a bad intermittent switch?
Thanks for the recall info aortizexcursion! That led me to just go ahead and pulled the wiper motor and sure enough that was it. Picked up a new one at auto zone and it's as good as new!
Sure, no problem. Glad to hear the Excursions back up and running regularly.
if it is recalled, why didn't you let ford fix it, at no cost to you...
how much was a new motor?
I believe recalls are only good for a certain time and I am not the original owner. Also it was a sunday on a holiday weekend and didn't want to wait. Last but not least... it's the wifey's and have to make sure everything is good to go for her.
Honestly though... I'm glad it happened to me and not her, who knows what could of happened if she had been driving it!
btw... the motor was $69 and change, they did require a core but had the old one in hand when I went in
