Lost It! Please Help
Old Dec 22, 2007 | 07:05 PM
scatgo's Avatar
scatgo
If you pull the plastic pice with the screen on it from th FPR there is a BB under it. I lost mine! Am I going to have to buy a new FPR because of it? I heard you can't get a screen. Dose any one know what size the BB is? Can someone measure theres with a micrometer and let me know what they have so I can see if I can find a ball bearing to fit?
Thank You
Old Dec 22, 2007 | 08:47 PM
timberjack's Avatar
timberjack
I'd guess your not the original owner of the truck? The bb was not oem, it's from an easy to do mod.
Do a search for "fpr shim" mod and i believe you'll find the bb is just a regular old .188" one. Hit the hardware store and get a whole tin of them. You can also leave it out too. From what i understand don't use a galvanized bb, interacts with the diesel fuel.
Ken
Old Dec 22, 2007 | 09:36 PM
scatgo's Avatar
scatgo
Its oem. It under the plastic part the screen is a part of. If you pull the plastic part out of the FPV its under it, a check valve ball. See part 9157 in the diagram in the following link....https://www.ford-trucks.com/forums/6...pr-screen.html.....I realy need to know what size this ball is. It could save me from having to buy a new FPR. Thanks.
Old Dec 22, 2007 | 09:57 PM
1997F-350's Avatar
1997F-350
i believe that may come in the $50 kit.
Old Dec 22, 2007 | 10:37 PM
scatgo's Avatar
scatgo
I heard you cant get them for a 94.5. Dose any one know if this is true?
Old Dec 23, 2007 | 04:06 AM
RubberDuck's Avatar
RubberDuck
scat, I discovered that the other day. One of my Death Row guys lost his screen. I had a bowl assembly on the shelf so I pulled the screen to give it to him. What do ya know something rolled out. I don't think it's a BB, it's more the size of buck shot. But it's plastic....I think. Anyway, I put it in one of my parts bin with some other fuel parts. PM me your address and I'll send it to you. If you are in a crunch for time, I can't help you. Christmas and all. But give me a few days and I'd be happy to send it.
Old Dec 23, 2007 | 09:54 AM
scatgo's Avatar
scatgo
Yea, Going to PM soon as I figure out how, never did it before. No rush. Iam wating on other parts that are going to take a while. Thank You Very Much........PS Yea I think It is plastic I got a quick look at it before it disapeard
Old Dec 23, 2007 | 11:38 AM
95psd's Avatar
95psd
It is a real pain in the a@@ but you can probably find it on the top of the engine. I had my screen fall down there and was able to get it back. I would think that a little ball might be easier to retrieve than a little screen.
Old Dec 23, 2007 | 11:47 AM
scatgo's Avatar
scatgo
Hand the filter housing in my garage whe I took the FPR off. I picked up the FPR and moved it about a dozen times without the screen in it forgeting about the ball being in it. Spent about an hour going through the garage looking for it but no good. It might have been in a rag that I had wraped around it. And of course the rag got tossed.
Old Dec 23, 2007 | 06:55 PM
timberjack's Avatar
timberjack
scatgo, sorry bout that, i was certain you were talking about the bb shim.
One more thing to tuck away in the memory if i ever need to take my fpr apart.
Old Dec 23, 2007 | 07:45 PM
scatgo's Avatar
scatgo
Yea, no sweet, after I posted I thought I might throw people off by calling the plastic check valve ball a BB.
Old Dec 24, 2007 | 01:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
BTW, somebody should tell everybody who is going to clean the screen, removing the FPR, that MUST be carefully with that plastic check valve ball, because, after reading about that, nobody mention it (to my knowledge), and when I did it, almost loose it.
