I wanted to change my tire size on my SCT x3, and I finally found what the rev/mile was for it. So when I went back into change the parameters there were Saved parameters and Default parameters. Now on the saved parameters everything was jacked with wierd signs and the speed limit said it was 60 mph. and all wierd stuff like that. "whats going on with that!" So I just went into default parameters and everything looked normal, or stock, so I changed the rev/mile there to 560 for my 37" tires(got the info from toyo tires .com) correct me if I am wrong.
Also what is data logging?
And there was no thing that said loading street, performance, or what ever so I just want to make sure I loaded the right one, anyway to do that?
What I need is a basic runthrough other then the manual to know that I didnt screw anything up.
... so I changed the rev/mile there to 560 for my 37" tires(got the info from toyo tires .com) correct me if I am wrong.
1) Your revs/mile with 37's is close enough at 560
2) Data logging is a feature in which you can record upto 20 different perameters for future use. The data is often used to determine problems and identify improvements that can be made to tunes.
