1978 - 1996 Big Bronco
Engine Error Code P0420?
Old Dec 22, 2007 | 02:58 PM
Broncobudy's Avatar
Broncobudy
Unhappy Engine Error Code P0420?
What does Code P0420-Catalyst System Efficiency Below Threshold (Bank1) mean?
Old Dec 22, 2007 | 05:06 PM
screwy's Avatar
screwy
Means your cat is on it’s way out. That or your o2 sensor.
Old Dec 24, 2007 | 09:52 AM
Broncobudy's Avatar
Broncobudy
Unhappy
OK, I cleared the code and the engine light came back on after about 2 days of regular driving.
This is the what my engine shows at normal operating temperature:
O2S
At Idle 680 RPM/ 1500 RPM
B1 S1 0.305 /0.720
B1 S2 0.130 /0.115
B2 S1 0.780 /0.380
MAF:
0.775 /2.152
Any suggestions?
Old Dec 27, 2007 | 06:06 PM
Trublufords's Avatar
Trublufords
If you are not concerned that the cat is not doing what it is designed to do, install a MIL eliminater in the oxy. sensor wire harness.Just a jumper harness plugged in between plug to oxy. sensor(fools PCM).The only way I have cured this code and it stayed away was to replace the cat OR if Ford has an update for this code-reprogram PCM to latest calibration.96 was the first year for OBDII and don't recall ever having a TSB For updateing PCM to cure a P0420.(did alot of Crown Vics though) Google MIL eliminater for more info! lol Blue
Old Dec 27, 2007 | 06:17 PM
Broncobudy's Avatar
Broncobudy
Red face
Thanks. I will look it up.
amill
Nov 8, 2012 03:20 PM
mlytc
Aug 14, 2012 07:52 AM
kjk
Aug 12, 2010 11:37 AM
hillclimbin
2004 - 2008 F150
Jul 27, 2010 01:01 PM
50th ann
Modular V8 (4.6L, 5.4L)
Jun 9, 2005 09:52 AM
