P0420 Trouble Code
Old Jun 8, 2005 | 05:18 PM
50th ann's Avatar
50th ann
P0420 Trouble Code
What should I do about a code P0420?
Catalyst System Efficiency Below Threshold.
Any help will be appreciated.
Old Jun 8, 2005 | 11:21 PM
LxMan1's Avatar
LxMan1
It usually means that a cat is not properly working any more.
You can try swapping the rear O2 sensors from one side to the other and see if the problem switches banks. If it does, then a bad O2 sensor is probably the problem. If you swap sensors and the light comes back with the same code, then the cat is probably not working as it should. You must reset the PCM to clear the codes before restarting after the swap.
Old Jun 9, 2005 | 09:52 AM
Bliath's Avatar
Bliath
I have the same problem. Does this problem with the Cats and/or O2 Cat sensors Sensors turning on the CEL light at all cause engine preformance problems or damage if gone unchecked ( meaning if the sensors are getting poor readings, is it sending a single to my truck to preform differently), Or is it just more pollution from my truck and no real concern? I have not had time to change sensors and it is too expensive to change Cats. I was just hoping to be reasured.
ckellis89
2004 - 2008 F150
Apr 5, 2016 06:16 PM
amill
1978 - 1996 Big Bronco
Nov 8, 2012 03:20 PM
kjk
Aug 12, 2010 11:37 AM
hillclimbin
2004 - 2008 F150
Jul 27, 2010 01:01 PM
Dialtone
General Automotive Discussion
Mar 31, 2008 02:47 PM
