Unassembled auto hub *pic*
Old 12-22-2007, 01:23 PM
distortedcloud's Avatar
distortedcloud
distortedcloud is offline
Well, I actually got to unassemble the hubs to service them. Heres a picture of all the parts. I will put it back together in a few minutes so if you other pictures type quickly.
Old 12-22-2007, 02:31 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
It may be too late, but how did you get the locking **** off and diaphragm out?
What does the back of the locking **** look like?
What seals the locking **** to the hub?
Where did the flat metal washer come from, that is to the upper right of the diaphragm iin the picture?
I see 2 big snap rings in the picture. I know one is on the back side of the hub and must be removed to get the gears and stuff out, but where did the other one come from?
Old 12-22-2007, 02:45 PM
distortedcloud
I'll see if I can explain it at all.
You have to work it from the back (its pretty straight forward for this part). Unassemble everything till you get to the rubber diaphragm. Now when you get to the diaphragm, you have to pull it down to help release the dial. To remove the dial, it has to line up with the three tabs on the hub then you can pull it straight out. Unfortunately, I just finished putting it back together.
And the other retaining ring is holding the metal washer which is holding the diaphragm in place. Hopefully this clears up some questions, obviously I'm not the best to explain things.
When I pull it apart again one day, I'll get more pics for ya.
Old 12-23-2007, 12:12 AM
jtharvey's Avatar
jtharvey
jtharvey is offline
I've had them apart down to the diaphragham, just couldn't figure out how to get the diaphragham and dial out. Since I just had them out a couple weeks ago and they seem to be working smoothly, it will probably be a while till I tear into them again. I may see if I can find an auto-locker that someone isn't using anymore, who has maybe switched to Warns, and tear into that one.
Heritage04
12-31-2009 08:43 AM
FunkyChicken
08-05-2008 08:48 AM
agferna
1997-2006 Expedition & Navigator
01-09-2008 05:36 PM
FordPUs
19
01-26-2006 06:56 AM
surveyor
03-17-2004 11:13 PM
Quick Reply: Unassembled auto hub *pic*
