2002 Explorer 4x4 Not Engaging When Cold
Old Dec 22, 2007 | 08:55 AM
craigyp's Avatar
craigyp
I have a 2002 Explorer XLS that won't engage 4x4 when first started in cold weather. This is the 5th winter I've had it and the first time I've had this problem. Last year I had a flashing 4x4 dash indicator, and found that the ground wire had corroded off my transfer case selector motor.
When I hit the 4x4 button now, nothing at all happens. No dash indication, no front wheels engaging, no noises (that I used to hear). After driving for about 15 minutes, the 4x4 works fine and will switch readily. Same problem in 4 high and 4 low.
I've only had this problem this year since the temperature has been below freezing, and I don't have any issues when the temperature is above freezing. What component of the 4x4 system could be affected by cold?
Any takers?
Old Jan 7, 2008 | 07:51 PM
amish77's Avatar
amish77
The selenoid may have to force against locked components when cold. This could be an oiling problem. WHen was the last time you changed the transfer case fluid?
Old Jan 21, 2008 | 06:36 PM
craigyp's Avatar
craigyp
Had the transfer case fluid changed last year. Probably won't hurt to change it again.
Any other ideas?
Old Jan 21, 2008 | 06:53 PM
antony25's Avatar
antony25
Very common problem. likely a faulty 4x4 module.
Old Jan 24, 2008 | 06:49 PM
craigyp's Avatar
craigyp
Thanks very much. Will have to give it a try. Can anyone tell me where it is located and what it looks like?
Old Jan 24, 2008 | 07:28 PM
antony25's Avatar
antony25
Behind the glovebox. Black plastic Motorola.
BGreener
1997 - 2003 F150
Jan 14, 2013 10:03 PM
yellow73bb
1997 - 2003 F150
Jan 1, 2009 10:59 AM
Wild Karrde
Mar 17, 2007 07:57 AM
azg129
Jan 28, 2005 10:07 AM
