dies while driving part two
Old Dec 21, 2007 | 10:23 PM
garyforsberg's Avatar
garyforsberg
went to the ford dealer and got the cps and put it in now the truck now the truck just dies it has to set for a minute before it will start again it dont buck anymore and the gauges dont go hay wire the truck just dies
Old Dec 21, 2007 | 10:49 PM
zx250's Avatar
zx250
Of the next Riffraff East
How long after you start it until it dies? Any certian things that causes it to die?
Old Dec 21, 2007 | 11:17 PM
garyforsberg
it happens when im slowing down or sitting at a light you can fill it stumble and miss a little
Old Dec 21, 2007 | 11:27 PM
zx250's Avatar
zx250
How is you oil level? I am still leaning towards a voltage problem. Slowing down also slows down the alt. and if weak don't produce as much volts. If the voltage drops below 10.5v(I think) the PCM resets. I remember in you other post you mentioned dealer and 2000 dollars, what did they do?
