dies while driving part two
went to the ford dealer and got the cps and put it in now the truck now the truck just dies it has to set for a minute before it will start again it dont buck anymore and the gauges dont go hay wire the truck just dies
How long after you start it until it dies? Any certian things that causes it to die?
it happens when im slowing down or sitting at a light you can fill it stumble and miss a little
How is you oil level? I am still leaning towards a voltage problem. Slowing down also slows down the alt. and if weak don't produce as much volts. If the voltage drops below 10.5v(I think) the PCM resets. I remember in you other post you mentioned dealer and 2000 dollars, what did they do?
