My 150 had its box removed and a flat deck installed. I spin the tires alot, because of the loss of that extra weight. What would be the stock numbers for a rear end for a 1994 F150 i6 auto. Or where would I find this information on the truck?
Reason I ask, is a buddy of mine suggested I buy his Dually rear end and install it. He says the rear end is out of a F250, but should bolt straight into my 150.
Check the driver's door jamb where it says axle code and post it up here for some of us to decode it.....really need to get some weight on that thing.......not sure about the dually rear end though.......
Hmmm thats interesting. If you dont want to spin the tires add weight or get bigger beefier tires. A couple hundred lbs of sandbags just make sure you strap em down they do alot of damage. Are you thinking about putting a regular box back on it? The stock rear end codes are either 18- which is 3.08 Non LS (Limited Slip) 19- 3.55 NON LS B6- 3.73 LS H9- 3.55 LS. The tag is on the drivers side door jam. To be fully honest i wouldnt deal with the heavy duty dually axle unless your planning on hauling alot of stuff. If so go for it but your going to have to beef up the springs as well.
I dont plan on hauling anything, I dont want to load the deck down with a few hundred pounds of crap either. Right now I'm paying $1.10p/liter for fuel (about $5 p/gallon), and the more weight the lower my gas mileage. I was hoping duallies would just fix the spinning tire issue.
Just convert your rear end to LS and it should solve your problem. Just buy a core return LS rear end at a salvage yard for $50 and take the LS stuff out of it and put it in yours. Use your ring gear and carrier and you will not have to set it up and you can use your old bearings.
Not a hard job to do and you do not need any special tools, you do not even have to drop the drive shaft. Just pull the axles and center carrier and put all the shims back in on the same side they came out of.
I have done about four 8.8" rear ends this way in the last two years with very good results.
Take the cover off the salvage yard rear end before you buy it and make sure the LS part looks good.
Ok now for the stupid question.... what the hell is an LS... I know basics, your now way over my head.... How do I find out what a LS is, is there specific markings to look for?
LS = limited-slip
Operation
The pressure between differential clutch packs opposes differential action at all times. When the vehicle turns a corner, the differential clutch pack slips, allowing normal differential action to take place. Under adverse weather conditions, where one or both wheels may be on a low-traction surface such as snow, ice or mud, the friction between the clutch plates will transfer a portion of the usable torque to the wheel with the most traction. Thus, the wheel that is on ice or snow will have a tendency to operate with the opposite wheel in a combined driving effort.
CAUTION:
Extended use of other than matching size spare tires on a Traction-Lok® rear axle could result in reduction in effectiveness (bias torque). This loss of effectiveness does not affect normal driving and should not be noticeable to the driver. However, extended usage will reduce the ability of the rear axle to provide added traction on slippery surfaces.
The limited-slip axle assembly is identical to the conventional rear axle (4001) except for the differential case (4204).
The limited-slip differential (4026) employs two sets of differential clutch packs (4947) to control differential action. The mounting distance of the differential side gear (4236) is controlled by seven plates on each side: four steel, three friction, and one steel rear axle differential clutch shim (4A324). This steel rear axle differential clutch shim is of the selective type to control the position of the differential side gear.
The plates are stacked on the side gear hub and are housed in the differential case. Also located in the differential case, between the differential side gears, is a differential clutch spring (4214), which applies an initial force to the differential clutch pack. Additional clutch capacity is delivered from the thrust loads of the differential side gear. Splined plates are splined to the side gear hubs which, in turn, are splined to the axle shaft (4234). The friction plate ears are keyed to the case so the differential clutch packs are always engaged.
Oops I made a bobo.
That should have read:
"Use your ring gear and the carrier from the salvage yard rear end and you will not have to set it up and you can use your old bearings."
If you use another ring gear and pinion then you will have to do the setup.
Can I just swap the entire rear end from the donor vehicle? Wouldn't that be easier? I dont have access to a shop, and my carport at my Apt they would rather I be very quick about any repairs i do.
